How about changing engine oil and brake fluid. Is that funny too? Changing fluids is standard maintenance on any vehicle. You're the first person I've run into that got a chuckle out of it.
Yes, Engine oil and a sealed fluid system are completely different.
From: Greater Detroit Metro MI, when I'm not travelling.
Originally Posted by Robls6
I agree 100% All these stupid threads about fluid changing make me laugh. You do more harm by removing the cap and introducing atmosphere into the reservoir than you do actually replacing the little bit of fluid in the reservoir.
Seriously. You buy a 50 - 80thousand dollar car, and then think you need to change the clutch fluid on it every single day, multiple times a day? Jesus christ... If the clutch hydraulics on the car were this bad you can rest assured NO ONE would ever buy it. The only people who subscribe to this myth are the ones who have been "enlightened" by this forum. It is a sealed system. Also, the distance between the slave cylinder where the hydraulic fluid sits, and the actual clutch plate where heat is generated, is so large, that you could VERY EASILY incinerate the clutch before the fluid ever got lukewarm. There is no heating of the fluid from a launch. If your clutch is sticking it is not because the fluid is getting hot.
I bought my car with 9400 miles on it, I drove it to the 74,000 miles it has today. 34000 of those were with a supercharger and it has had bolt-ons and a tune since 12K. Its been autocrossed and drag raced multiple times, and gets beat on daily. Stock clutch untill about 14K miles ago, with zero issues. I swapped it out when I didn't have to and regretted it.
I have changed my clutch fluid exactly twice in 3 years. The first time when I bought it, the second when I changed the clutch
The only problem I've ever had with my clutch hydraulics has been from installing an aftermarket remote bleeder kit; it failed and all my fluid leaked out.
But, if it's on the forum it must be true Sam. Oh... and Brian I haven't had any issues with the clutch at all and I have driven it hard enough to break the output shaft right off the trans. The only issues I have had with the car have been with the hack job work that was done when the supercharger was installed. I found some really ugly things when I put the Dewitts radiator in it. But that's another story.
I don't think anyone is advocating that. Like I said, at 5k miles my clutch fluid was low and thick black. I now change mine when it gets dirty, about once every 6 months. Takes ten minutes and one bottle of fluid from Walmart.
Going 5 years without changing your clutch fluid is simple neglect. Since clutch fluid is just brake fluid it should at least be changed as often as you change your brake fluid. Now don't tell me you still have the original brake fluid.
You havent had any issues with it because the car has Dot4 synthetic in it now. It has a much higher temp that it will boil at compared to the stock dot 3 regular. And I didnt install the blower, all I know is it worked fine for me. The only thing I had to do was change out the belt a few times. If you want to know who installed it, PM me and I will give you all the info. But the clutch fluid thing is real, and your car suffered from the clutch dead pedal syndrome until I started doing the ranger method.
Brian,
I'm not complaining about the car. As for the clutch fluid then you're right. If there is Dot 4 in there then I do not see any need to change it. Sucking out the reservoir and re filling it does NOT replace all the fluid as people here seem to think. It will only replace what is in the reservoir. I don't understand why you had problems with the belt on the car though. I have put over 8000 miles on it with no belt problems. I know who installed the blower and I wouldn't recommend them to anyone. Their work was sloppy at best and the tune was horribly rich. But after working out a few bugs everything is cool now so no big deal. How do you like your Mustang?
A July '09 GM bulletin said that fluid related clutch feel issues were cause by water in the fluid. It implied that frequent cap removal was a cause and to only inspect the fluid level by looking through the trasparent resevoir. GM recomends changing the fluid every 2 years.
WHAT???? But everyone on the forum says to change the fluid after every friday night cruise.... Now what should I do!
I had to change the belt from the gates belt that Andy sends out with the kit because it was chirping when cold. Very annoying. I broke the first one, the second one chirped and the third one that was finally silent was the gatorback.
The shelby is awesome. I just had me, my wife and our 8 month old daughter in it last friday at the rolling meadows cruise. The diaper bag, and stroller fit neatly in the trunk...LOL. Thats why I bought it. I do miss the vette, but the shelby is the perfect replacement for it. I heard you had issues with the bap fuse too? I would never go back to that guy either who installed and tuned it. I didnt know any better, but now I do.
You must think I'm like most and it's a garage queen. I replaced the brakes at 70K along with the fluid, 13 months of use. I just decided to change the clutch thinking it has to be near its end of life at 105K miles. Clutch looked like it was good enough for another 60K if not more, and yes I changed the cylinder and fluids at that time. Oh that was just under two years, now do you have anything else you would like to know, maybe the GM bulletin number involving improper machining of flywheel that leads to clutch hang up, damn was I suppose to say that.
I'm glad you like the mustang. It is a nice car. Yeah... I had a problem with the BAP last year ( it was wired in with crimp connectors!). I soldered it in and it was fine for a year but the fuse blew again last week when I was on it really hard. I bought a Racetronix harness and will be putting it in next week. I'll keep an eye out for you at RM or the other cruise nights.
