2005 C6 VSS replacement?
Old Jul 6, 2010 | 11:58 AM
NitrousMan's Avatar
NitrousMan
Default 2005 C6 VSS replacement?
I haven't got under the car but it sounds like the VSS is located in the rearend and should be easy to replace but if anyone has any tips they would be greatly appreciated. Thanks.
Old Jul 6, 2010 | 01:12 PM
cranky's Avatar
cranky
VSS is located on top of the diff housing on the pass side. easy replacement if you can raise the car up.
Old Jul 6, 2010 | 05:26 PM
NitrousMan's Avatar
NitrousMan
Thanks, shouldn't be to bad then.
To 2005 C6 VSS replacement?
