Zerk fitting on 09 C6
Old Jul 8, 2010 | 01:14 PM
kenedds's Avatar
kenedds
Default Zerk fitting on 09 C6
There is a small squeek on the left rear suspension on my 09 c6 that goes away after a few miles of driving - no big deal. But being **** about an otherwise quiet car are there zerk fittings on the suspension in the rear that require periodic grease?
Old Jul 8, 2010 | 02:10 PM
JoesC5's Avatar
JoesC5
Z06, ZR1 and Z51 equipped C6's have a Zerk on the rear toe link, each side.
Old Jul 8, 2010 | 02:38 PM
BEZ06's Avatar
BEZ06
with JoesC5.
However.....I can't imagine that you'd be getting a squeak from that area on an '09, unless they just didn't grease that fitting at all when it came down the assembly line!
But.....squirt some lube in there and see if it does anything for you.
Bob
To Zerk fitting on 09 C6
