everyone knows that GM has announced the all aluminum engine 5.5 L direct inj, 440hp motor for the C7. My question is what kind of weight savings are talking about with the all alum block vs the LS3 and what are the draw backs? I was told tonight that alum blocks are trash if the car ever overheats. True?
everyone knows that GM has announced the all aluminum engine 5.5 L direct inj, 440hp motor for the C7. My question is what kind of weight savings are talking about with the alum block vs the LS3 and what are the draw backs? I was told tonight that alum blocks are trash if the car ever overheats. True?
The LS3 has an all aluminum engine.
As do most modern cars.
There are no issues with an aluminum block that you need to worry about.
Provide a link to the GM announcement please.
All modern LS blocks are aluminum.
San
The LS3 is an aluminum block, and the severity of the overheat will determine block longevity. The piston will suffer metal transfer and the heads will suffer before the block.
Here's a link: http://usnews.rankingsandreviews.com...-5-5-liter-V8/
Couple of points, while the LS3 is mostly aluminum the liners are steel. The new 5.5 L may benefit from the technology showcased in the new 5.0 Mustang. The car enjoys a sprayed in lining that is more durable and lighter than the pressed in steel variety. As for overheating, I agree it's not an issue but was back when aluminum heads were used on cast iron blocks - that does not apply here
The engine block for the Chevy Vega's were also all aluminum with no steel liners. The head was cast iron though, to give the block rigidity. That was 40 years ago.
I haven't seen GM announce anything. The speculation is just that, speculation.
Originally Posted by Andy 53
Is that really necessary?
We see rumors on this forum all the time....some are true and some are not.
Andy
Ignorant means "not knowing". Everyone is ignorant to some extent.
It is clear the OP didn't know the LS3 is an aluminum block and has misconceptions about aluminum blocks.
San
The mere fact that he asked a question indicates that he probably doesn't know the answer. To tell him that he is "ignorant at best" adds no value. I suspect the OP was looking for an answer....I doubt he was looking for someone to tell him he was ignorant!
Yep and they were all blowing oil after a few years.
My advice is educate yourself about modern GM engines. I used to think as what you say you were told/heard but it's nowhere true.....aluminum is lighter than steel/iron. There could be some fact to the 'rumor' from engines developed by GM back in 60's/70's, but not all true at best. Today's aluminum engines are far superior to anything from back 'in the day'. The heads would go down before the block would, then pistons.....the pistons have 'iron sleeves' in cylinder walls. All aluminum engines are that (except sleeves-connecting rods-lifts-titanium).
Aluminum is lighter than steel/iron. So depends on size of engine as to weight saving. Thats also why Z06/ZR1 have aluminum frames as well as carbon fiber and balsa wood floors. I owned a '09 LS3 Z51 Roadster. I can tell you that it's far better engine than the 427 engine of the 60's....***in terms of performance*** as not to offend......it's power to weight ratio outranks 'it's kin by 25-40% because of cube difference and material leading to further weight reductions as well. 427 cubes of iron/steel -vs- 378 cubes of mostly aluminum that makes equal ponies in it's base form. My advise is to read up and be informed instead of listening to rumors.
Had nothing to do with the all aluminum constructed block. It was the Blockhead engineer that spec'd a mild steel head gasket that caused the problem. Head gaskets started leaking coolant into the cylinders washing down the walls which wiped out the oil control rings. As soon as Chevy realized they had a problem, they changed the head gasket to stainless steel, and that cured the oil usage problem, but the PR damage was never fixed.
My 56 vette is lighter then my 09 Z06. The only aluminum used on my 56 are the pistons and the wedges between the front frame rails and the front suspension crossmember. The block is iron/steel as is the intake, the transmission case, the frame, the springs, suspension A frames, and on and on and on. Radiator is brass/copper as is the heater core. Not one piece of carbon fiber on my 56 and it has the old style fiberglass body, not the lighter SMC panels.
I wonder how much weight I would drop and how much performance I would gain if I yanked the old cast iron 265 ci engine and replaced it with a new aluminum 427 LS7?
Do not let your heart be troubled, if GM builds the next gen V8 it will incorporate many new modern features and improvements over the LS3. Should be interesting. Ford seems to be playing catch up.
