What should BCM Voltage be???
Old Jul 13, 2010 | 09:15 AM
Charley Hoyt's Avatar
Charley Hoyt
Default What should BCM Voltage be???
Does anyone know what the voltage from the BCM should be when it is triggering a relay? I would assume that it should be ~ 12 volts...but I am seeing ~10V.
Thanks,
Charley
Old Jul 13, 2010 | 12:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
All relay actuation voltage should be battery voltage. If the engine is running,,it should be alternator output voltage.
How are you reading the voltage? Make sure your using a good clean solid ground surface for the meter ground wire.
BC
Old Jul 13, 2010 | 01:00 PM
Charley Hoyt
BC
Thanks Bill. The way I am reading the voltage is by removing the relay and then using a multi-meter to measure the voltage from the slot where the relay mounts and the actual ground point for that relay (specifically G202, which is a bolt to the frame near the passenger door). For the power to the switched side of the relay (the part that will be switched on by the actuation voltage) I read battery (or alternator voltage). When I measure the actuation voltage I am getting about 2 volts less.
Thanks for the help.
Charley
Old Jul 13, 2010 | 05:17 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Charley
What relay and what circuit? What issue are you seeing?
BC
Old Jul 13, 2010 | 05:47 PM
Charley Hoyt
BC
It is the relay for the Tonneau release. The schematic is on Page 12-5 of the 2008 Service manual. The issue is that when I try to lower the top, the tonneau cover starts to release but the latch does not fully release the tonneau. If I then release the switch commanding the roof to lower, the tonneau latch releases. I can then press the roof switch again and the top will fully lower. The interesting thing is that when the top is down and I am trying to raise the roof...the tonneau latch operates normally. The dealership has replaced all of the limit switches and the tonneau latch. In the process of checking all of the wires I found the issue stated above and I am trying to discern if it could be the cause.
I appreciate any recommendations you may have.
Charley
Old Jul 13, 2010 | 06:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do you have the CM7 top option??
What resistance reading do you get if you read the GROUND PIN in the relay socket to a good clean chassie ground??
If you want, I can send you the schematic
BC
BC
Old Jul 13, 2010 | 09:57 PM
Charley Hoyt
BC
BC
I have high resistance in the ground....If I measure between the ground pin and a ground close by I get a reading around 35 ohms. when I measure going to the G202 ground location I get ~55 ohms.
I have a copy of the schematic....but, I could use a wire routing diagram to better trace the ground routing and the power wire routing so that I can check it for opens / grounds/ crimps, etc.
Charley
To What should BCM Voltage be???
