O2 Sensors when installing long tubes
Old Jul 13, 2010 | 11:41 PM
res0n0xg's Avatar
res0n0xg
Default O2 Sensors when installing long tubes
I did some searching... do you HAVE to have the front / rear O2 sensors? I have a full tune, and will be going back after the install for a retune and keep hearing you can "tune" them out using HP tuners, but usually people are referring to the rear O2 sensors only... is that true? I will be going with a catless system if that makes a difference.
Old Jul 14, 2010 | 01:20 AM
tjwong's Avatar
tjwong
You need the front sensors only. The rears only monitor catalyst efficiency. If you have aftermarket metallic substrate CATs that come with most header kits, the rears will not see the same signals that they expect to see with stock ceramic substrate CATs. Having said that most will either leave the rear sensors out or tune them out and leave them in place in case of a visual inspection.
