Difference between 06,07 and 08 Z06
Old Jul 20, 2010 | 10:04 AM
jmyokley's Avatar
jmyokley
Default Difference between 06,07 and 08 Z06
I am sure this has been discussed before but I am not the best with the search tool. Point me to a link if this has been hashed over and over....
I am looking to buy an 08 Z06 but if I look at 06 and 07 along with the 08 Z06 there are many more to chose from.
What are the MAJOR differences between the year models and what should I be aware of with certain year models.
I have been told that the 08 Z06 has an upgraded transmission, is this correct?
Thanks,
John
Old Jul 20, 2010 | 11:16 AM
RicK T's Avatar
RicK T
Thanks,
John
Yes on the transmission.
The major changes were:
T6060 transmission in place of the previous T56
Improved steering feel via improved machining and tolerances of the rack.
Hydrocarbon center console finish
Old Jul 20, 2010 | 11:38 AM
jmyokley's Avatar
jmyokley
Thanks for the reply. I have been looking only at 08 Z06's due to the transmission upgrade BUT have located a very nice low milage 06 Z06 at a good price. I was just steering away from the earlier Z06's thinking there were more issues.
I guess there would be no warrenty left on an 06.
thanks again.
Old Jul 20, 2010 | 02:25 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
If the seller of this 06 Z06 has an extended warranty, such as the GMPP, it can be transferred to you for something like $50. I just bought my 06Z and the paperwork is in the works right now to have the GMPP transferred to me. Just a thought... see if he's got that warranty!
Old Jul 20, 2010 | 02:43 PM
NORTY's Avatar
NORTY
Yep, the difference is "steers and gears". Also, slightly more insulation (cabin) was added for 2008.
Now, whether you want to call the TR-6060 an "upgrade" over the T-56 is up to you. Your call.
Old Jul 20, 2010 | 03:04 PM
JJC5's Avatar
JJC5
'07 and later has the factory 5yr/100K power train warranty too.
Old Jul 20, 2010 | 05:46 PM
jmyokley's Avatar
jmyokley
Thanks.... I have asked the guy to look into this.
Old Jul 20, 2010 | 08:08 PM
ctusser's Avatar
ctusser
Too bad they have the time limit. If it was just a strait up 100K warranty it would be a lifetime warranty for many a vette owner
Old Jul 20, 2010 | 08:56 PM
Pimpedc6's Avatar
Pimpedc6
If I recall correctly:
steering improvements
Dry oil sump system
TR6060 which is rated for 600LB ft of torque continous use- TR56 rated for 460LB ft of torque
TR6060 is suppose to be a big improvement especially if you plan on modding the car.
To Difference between 06,07 and 08 Z06
