Check Engine Light - 9 Codes!
Old Jul 21, 2010 | 02:32 PM
dsmboosted's Avatar
dsmboosted
Default Check Engine Light - 9 Codes!
My check engine light went on about 3 weeks ago and I finally took it into the dealer today to see what the codes were. There were 9! Holy crap. I'm wondering if anyone has any insight as to exactly what these codes are. My tuner is an hour away. I am wondering how much a dealer could do on a car modified like mine. Any thoughts?
p0833 clutch pedal switch
p0442 evap small leak
p0621 generator L termanal circuit
p0454 puel tank pressure sensor
p0108 map circuit high voltage
p0455 evap large leak
p0175 bank 2 rich
p0174 bank 2 lean
p0171 bank 1 lean
On a side note, I had the car re dyno tuned about 4 months ago and there were not any codes thrown.
Mods
*MP122 magnacharger @ 5psi
*LG pro Z06 longtube headers with highflow cats
*Z06 stock exhaust
*mild to wild switch
*Cam spec= 224/228 .581/.588 114lsa
*TSP ported heads w/ stock width head gaskets
*K&N Z06 filter element
Old Jul 21, 2010 | 03:48 PM
VET4LES's Avatar
VET4LES
A weak battery can cause codes but I would talk to your tuner and see what he thinks. You have a lot of mod's that could be causing a problem.
Old Jul 21, 2010 | 03:54 PM
MARSC6's Avatar
MARSC6
The first thing I would check is the negative terminal on the battery.
Old Jul 21, 2010 | 09:27 PM
res0n0xg's Avatar
res0n0xg
I'd also lean toward electrical, not mechanical on that one...weird to see a lean and a rich code, I guess your tune could be lean rich
Old Jul 21, 2010 | 10:47 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I had a C4 that threw a bunch of codes once and it was the battery going bad. Once the voltage drops below a certain point, the sensors would send a lower than normal voltage signal to the PCM/BCM which was interpreted as a fault.
If it were my car, I would look closely at the battery/cables first.
Old Jul 22, 2010 | 11:09 AM
dsmboosted's Avatar
dsmboosted
Good Call. I actually put a new battery ion not to long ago. But there were some electrical problems when the car was getting dyno tuned. The car was showing almost no voltage, and was acting very odd. Sometimes starting, sometimes not. Sometimes the fob was recognized, sometimes not.
Long story, the mechanic cleaned out the fuse box and the car ran fine. I will look into the battery and fuses. Any more recommendations for electrical cleaning/checking?
Old Jul 22, 2010 | 02:26 PM
Mez's Avatar
Mez
Check the negative cable to ground. What is the voltage before you start it?
Old Jul 22, 2010 | 06:06 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
I would invest in a small hand held code reader, so you don't have to take your supercharged car to the dealer and have your tuner take a closer look at the calibration.
Old Jul 23, 2010 | 12:12 PM
dsmboosted's Avatar
dsmboosted
I turned the car on today to see what the voltage was at and the dash said 14.2 volts. i checked it right away after start up. The car has been sitting for about 5 days because I forgot to latch the top down and it blew off and its been raining a lot.
Old Jul 24, 2010 | 07:14 PM
seevi's Avatar
seevi
Check battery, grounds and alternator.
To Check Engine Light - 9 Codes!
