Trouble shifting in S-mode only!
Old Jul 23, 2010 | 09:41 PM
rhoward2's Avatar
rhoward2
Default Trouble shifting in S-mode only!
Hi, When in S-mode (and only in S-mode with or without using the paddles) my transmission hangs between 4th and 5th gears. Under heavy throttle it almost acts as if it's momentarily hitting 3rd gear as it will really wind up before shifting to 5th (doesn't hit rev limiter). At less aggressive acceleration it will make a whining noise right before shifting to 5th. Has anyone experienced problems with their A6 transmission like this, and if so, what caused it? Any help will be greatly appreciated. Fluid was a bit dark, but no metal or plastic in it. Shifts great in D-mode. Help!
Old Jul 24, 2010 | 12:40 PM
Elless2's Avatar
Elless2
Mine is having similar issues with 3-4-5 shifts. Dealer called the engineer and the tranny has to come out to look at seals, clutches, and the torque converter.
Old Jul 24, 2010 | 11:29 PM
speedwaywhite's Avatar
speedwaywhite
Check out PIP 4395, my 08 coupe is waiting for the parts to arrive to do the fix called for under this service bulletin
Old Jul 26, 2010 | 12:25 PM
rhoward2's Avatar
rhoward2
Please keep me posted as to what you learn.
To Trouble shifting in S-mode only!
