ExtremeContact DW
Old Jul 24, 2010 | 02:45 PM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
Default ExtremeContact DW
Another tire option. I am wondering if anyone has tried these on the Vette. Reviews are positive and pricing is very competitive.
They now come in stock C6 sizes and +20mm which I use in PS2; 265/35-18 & 305/30-19 with XL designation.
http://www.tirerack.com/tires/tires....remeContact+DW
Old Jul 29, 2010 | 03:43 AM
thetight's Avatar
thetight
That's what ihave on the back 305/30/19 I love them!
Old Jul 29, 2010 | 07:54 AM
tomiboy's Avatar
tomiboy
Did you notice how light they are? Another plus!
Old Aug 1, 2010 | 05:01 AM
LBear's Avatar
LBear
The sizes you quoted, will they fit on a STOCK C6 rim?
The OEM is 245/40/18 and 285/35/19
The tire did get good ratings BUT the tread pattern seems very "non-aggressive". When compared to the GSD3 or Exclaim UHP, the Continental tread pattern seems tame.
Anyone have these on their car and how are they holding up?
Old Aug 1, 2010 | 05:21 AM
thetight's Avatar
thetight
Yes those sizes will fit on stock size wheel and they look and perform much better then stock tires and stock size. Gm should have used this size from the start. I've got just over 4 k miles sofar and they are holding up great.
Old Aug 1, 2010 | 05:26 AM
thetight's Avatar
thetight
Also my car is an a6 and has just a few bolt ons and with the run flats I would have traction issues from 0-20mph. With these they might chirp a little from a stop but that's it they hook very well! Love em
Old Aug 1, 2010 | 06:08 AM
LBear's Avatar
LBear
Did the larger size throw off the speedo?
Any clearance/interference issues?
Do you have a pic of what they look like on your car?
Old Aug 1, 2010 | 04:14 PM
thetight's Avatar
thetight
What's your email I'll send a pic. No issues at all with clearance or speedo. I'm telling you gm should have used this size from factory.
Old Aug 1, 2010 | 05:13 PM
tdelena's Avatar
tdelena
I run these sizes in PS2 and they are awesome. Technically they are 1/2" too big, but I have found no issues. I think the XL (extra load) designation provides a little stiffer and reinforced sidewall which helps. In addition, the 30 and 35 profiles yield smaller sidewalls to prevent the larger tires from any unwanted movement on the stock width wheels.
Old Aug 1, 2010 | 11:05 PM
jbirdblack's Avatar
jbirdblack
These are great tires and priced rightt I love mine!
Old Aug 1, 2010 | 11:19 PM
LBear's Avatar
LBear
PM sent!
I went to that tire calculator site and it showed that the different sized tires would create a 2.4% speedo error. When the speedo reads 60MPH, you are actually going 58.5 MPH. I guess that is not much of a difference there. Very minor.
Do you also run the Continental ExtremeContactDW in:
265/35-18 & 305/30-19 with XL designation?
How is the road noise and handling of these tires?
Old Oct 11, 2010 | 12:08 AM
jpuli28's Avatar
jpuli28
Im looking at these for the oem rims too, what size did you put up front? (assuming you have 18x8.5)...
To ExtremeContact DW
