Tunnel plate Question
Old Jul 25, 2010 | 10:37 PM
Res1cue's Avatar
Res1cue
Default Tunnel plate Question
Has anyone tried to bond 2 tunnel plates together using maybe RTV silicone or JB weld instead of buying a aftermarket plate. 2 factory plates bonded togeather = 1/4
Old Jul 25, 2010 | 11:17 PM
Sparo2's Avatar
Sparo2
One solid piece is always stronger than two pieces glued together.
Old Jul 25, 2010 | 11:36 PM
c6 batmobile's Avatar
c6 batmobile
My buddy riveted 2 pieces together on his C5 using something like 80 rivets. It seems to work pretty good for him.
Old Jul 26, 2010 | 12:29 AM
lockman's Avatar
lockman
never tried it but if you want a second factory one I'll sell you mine it's just sitting in the corner right now. let me know
Old Jul 26, 2010 | 08:17 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Not exactly.
In both bending and twisting, the interface between the two plates is at the neutral axis, and the two plates have no tendency to slide against each other.
Sandwiching two together is OK. I added a s 1/8" spacer between two plates for even more stiffness. Less than a 3/8" plate though.
Old Jul 26, 2010 | 09:17 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Might work but the commercial replacement plates like those from Elite Engineering also are available with ceramic coating which helps reduce heat transference into the cockpit area.
To Tunnel plate Question
