FOB Issues
Old Jul 26, 2010 | 12:27 PM
dsmboosted's Avatar
dsmboosted
Default FOB Issues
My fob is acting up. I get the error message on the dash that says fob not present. I have the fob in my pocket and I just put a new battery in. The car wont start because its not recognizing the fob. So i put the fob in its holder on the glovebox and it recognizes it and the car will start. ANy thoughts? I nly have 1 fob and im going to buy another right now.
Old Jul 26, 2010 | 01:12 PM
HOXXOH's Avatar
HOXXOH
Possibly the battery you just bought has the gridded negative surface. The correct one needs to have that surface smooth. It's due to the tiny spring contacts in the fob that have trouble making full electrical connection.
Old Jul 26, 2010 | 01:27 PM
dsmboosted's Avatar
dsmboosted
the surface is smooth on the negative side.
Old Jul 26, 2010 | 02:51 PM
MP35N's Avatar
MP35N
Default Gremlins
I've had it act up before as well. I believe it is due to outside radio interference because it pulled the same stunt with a new battery. ON Star was totally useless. Do a search, there are other threads on this, but no good answers.
Old Jul 26, 2010 | 03:36 PM
VET4LES's Avatar
VET4LES
Usually when this happens the battery was installed upside down. There is a + and - .
Old Jul 26, 2010 | 03:47 PM
dsmboosted's Avatar
dsmboosted
the originally battery that was in there was almost new. I just tried outting a different one in to see if it was the battery. Its 100% not the battery.
Old Jul 26, 2010 | 03:59 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Both mine are actin up like a son'beach. I chalked it up to FOB battery issues but if that doesn't take care of it I'll be .
Old Jul 26, 2010 | 04:11 PM
robertaj's Avatar
robertaj
oddly enough I have a magnetic money clip... and when the fob is in the pocket with the money clip it doesnt get recognized.... make sure you dont have anything like that in your pocket.. i imagine a cell phone could have the same effect
Old Sep 8, 2010 | 05:55 PM
5 Liter Eater
St. Jude Donor '11
FYI new batteries fixed mine up good.
CR2032 is the batery #.
Old Sep 9, 2010 | 07:01 AM
seevi's Avatar
seevi
I found that pressing the Mild 2 Wild fob at the same time you try to start the car interferes and gives me the no fob present error message.
Old Sep 9, 2010 | 11:00 AM
torquetube's Avatar
torquetube
Try the spare fob. If it works, there's something wrong with the first one.
If neither fob is recognized, you may have a radio interference problem. My C6 would only intermittently recognize any of my fobs whenever it was parked in my garage. I switched off the breaker to the garage door opener, and the problem instantly went away.
In my case, the receiver in the door opener was jamming fob communication.
Take all the electric gizmos out of your pockets/glovebox/center console/trunk, drive to a few different locations, and attempt to restart the car at each one. If the fobs still aren't being seen, you could have a RDCLR problem.
Old Sep 9, 2010 | 11:20 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
I have to wear a pager for work. I'm finding that if the fob is on the same side as my pager it doesn't work. So, cell phone or ipod or anything like that next to the fob?
Old Sep 9, 2010 | 02:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try placing the FOB close to the area around the radio, HVAC control panel. When mine acts up thats all I have to do works fine. There are receivers for the ignition switch and both doors. The area where they will pick up the passive fob is pretty small and is easily corrupted.
Old Sep 9, 2010 | 05:30 PM
5 Liter Eater
St. Jude Donor '11
<Imagining Bill C waving his crotch around the radio/HVAC area with fob in pocket>
Seriously though when I have trouble with mine it is usually getting into the car that is the problem. But if the battery is really low I need to have the fob in my right pocket for it to start.
Old Sep 9, 2010 | 05:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
That would be a good trick! I normaly dont put my fob in my pocket. I toss it in the cup holder.
To FOB Issues
