Plug Wires
Old Aug 1, 2010 | 10:45 PM
jsilvz's Avatar
jsilvz
Default Plug Wires
Are aftermarket wires better than the factory wires for a bolt on or H/C car? Let's say MSD for instance. Did a search, didn't find much.
Any opinions?
Old Aug 2, 2010 | 12:26 AM
HANNY's Avatar
HANNY
the core wire on some is bigger allowing full voltage, of course there is a limit, its like a 10 gauge speaker wire versus a 1 gauge speakere wire. it can only allow full power so whats the point of the bigger wire? the factory wires are known for a great core and good rubber resistance parts to help keep the voltage going from the coil to the plug and also not letter RF leak out and static your radio and other components. For me if the msd is similiar in price the ngo for it, if they are double then i dont see the point. Check the core wire grade against the stock ones.
but some guys sware but certain parts,,,im sure ther is someone who claimes he picked up 2 seconds in the 1/4 just switching to msd wires
Old Aug 2, 2010 | 01:56 AM
LS1LT1's Avatar
LS1LT1
In my opinion, no.
The stock plug wires (as long as they're still somewhat new/fresh) are pretty damn good.
Old Aug 2, 2010 | 03:17 AM
3 Z06ZR1's Avatar
3 Z06ZR1
I just put on MSD's yesterday. My Z-06 seems to idle nicer and run better over-all. Big Change NO. Noticible yes. Much better wire than the stock wire. No contest. Stock wire is smallish at 7mm. Can't be too good.
For 66.00 dollars from Auto Zone. I'd do it for sure. Those that haven't shouldn't comment. Make sure to use the die-electric
grease on the plugs and reuse the factory heat shields.
Old Aug 2, 2010 | 06:14 AM
timd38's Avatar
timd38
I changed to performance wires just before I put headers on and I can't say anything changed.
Old Aug 2, 2010 | 12:18 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
There really shouldn't be a performance difference if the factory wire is not compromised at all... BUT
The MSD has better features to it than the factory wire and make it a better choice if your adding headers.
hi heat resistance silicone
multi-angle spark plug boot
lowest amount of resistance
MSD's 8.5mm Super Conductor wire sets have a special helically wound core that has just 40-50 ohms of resistance per foot--but with an RFI suppression equal to a 1,500 ohm wire. In fact, each foot of finished wire features 40 feet of tightly wound copper for superior conductivity. A tough 8.5mm synthetic/silicone jacket over an extra-heavy glass braid and dielectric insulator keeps the current guided to the plugs. Underneath the high-temperature boots, dual crimp stainless steel terminals feature snap-locks to ensure a secure fit.
In addition I offer them for the best price you will find anywhere as well as packaging them with spark plugs for the best price as well.
Old Aug 2, 2010 | 12:46 PM
ninjavette's Avatar
ninjavette
How many miles on your stock wires?
Old Aug 2, 2010 | 07:19 PM
jsilvz's Avatar
jsilvz
car has about 20k on clock. pulled one wire in half pulling the boot off plug. was able to buy just one single wire at the dealer.
thanks for replies
Old Aug 2, 2010 | 07:26 PM
Stormcrowe's Avatar
Stormcrowe
Best price I've found, 68$ for the wires and TR6's +free shipping
One of my coil boots was slipping and arcing some, replaced with this kit and I'm very happy with the results. 8 good wires > 7.5
Old Aug 3, 2010 | 01:35 PM
99blancoss's Avatar
099blancoss
Former Vendor
thanks for replies
Unfortunately that happens quite a bit and with Taylor wires as well. Its due to the construction of the wire. MSD uses a double crimp system that prevents that. By crimping the jacked and the filament separately the MSD has greater resistance strength to being pulled apart. That coupled with the fact if you pull one of my wires apart I'll replace it for free for the life of the wire.
We offer single replacement wires as well as a 4 pack.
Old Aug 3, 2010 | 07:23 PM
jsilvz's Avatar
jsilvz
99blancoss
if I break another one I'll give you a call
thanks again
Old Aug 3, 2010 | 07:50 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Many aftermarket wires are not worth any extra power, but can sometimes be found for cheaper then the stockers. There is likely no power to be gained with them so don't believe everything you read on the internet. I will say that it is a well known fact that MSD coils are absolute junk and I would never recommend running them.
Old Aug 3, 2010 | 08:15 PM
vette06nj's Avatar
vette06nj
I thought some people were complaining about fitment problems with MSD wires, so I just went ahead and purchased Callaway plug wires. They are a bit more pricy, but fitment is perfect; they work as intended; high quality construction; and look good.
Old Aug 4, 2010 | 05:22 AM
99blancoss's Avatar
099blancoss
Former Vendor
Yep MSD LS coils have had plenty of issue and are not worth the money, well known.
BUT MSD 8.5mm Superconductor wires are a premium wire and are actually better than most and is one of the best wires on the market.
I'm not sure where anyone has said you gain performance by swapping wires.. I certainly haven't. This is what I have said though:
with a quote form MSD's website
In addition I offer them for the best price you will find anywhere as well as packaging them with spark plugs for the best price too.
I thought some people were complaining about fitment problems with MSD wires, so I just went ahead and purchased Callaway plug wires. They are a bit more pricey, but fitment is perfect; they work as intended; high quality construction; and look good.
I have not heard of that at all. The MSD boot is multi-angle and can be manipulated to a 90* or more if need be. AT $58 its the best option on the market. There are more expensive wires out there for sure. I've seen them for as much as $180. But at 8.5mm and being built as they are it honestly is very hard to beat our MSD wires. Plus they are guaranteed for life vs defects. Come in red or black
Old Aug 4, 2010 | 01:19 PM
mittens's Avatar
mittens
Taylor wires, I like them better than MSD, an dcome in every color, and do not break when you take them on and off. also they do not touch my headers.
Old Aug 4, 2010 | 01:27 PM
99blancoss's Avatar
099blancoss
Former Vendor
I'll be honest with you. Taylor wires are why I got into business in the first place and make MSD. They break and pull apart due to the single crimp system, they are a horrible wire to be honest with you. More people have trouble with Taylor wires breaking than any other brand.
I've got some photos to illustrate what I am saying I'll dig them up and post them for people
Old Aug 4, 2010 | 01:32 PM
Rickmd's Avatar
Rickmd
I agree. Plus the spark plug boot is sealed to the wire. Note: Harbor Freight has a flexable SP wire puller on sale for $1.99 that makes removal much easier without damage.
To Plug Wires
Old Aug 4, 2010 | 01:46 PM
wmckeenster's Avatar
wmckeenster
Do you have a coupon code?
Free Shipping?
Old Aug 4, 2010 | 01:49 PM
99blancoss's Avatar
099blancoss
Former Vendor
Not sure what you mean by coupon code ? We offer the best deal on the planet already
Yes shipping is free the the US and its territories
Here you can see one of the 3 the Taylors that broke on my car first time I swapped plugs.
Notice the huge difference in the heads that attached to the spark plug. Single crimp vs double crimp... not even a question here of what is better, the picture does tell the story.
Then look at the coil end. MSD on left Taylor on right. the MSD has longer crimping ears than the Taylor.
This was a Taylor Thundervolt 10.4mm wire. More expensive and absolute junk IMHO.
If you want a good wire, best for your money then come see me and I'll build you a set guaranteed for life vs defects. You pull one of my wires apart or break it like that and I'll send you a free one for as long as you own the car... and yes I'll even honor a transfer if you sell the car
Old Aug 4, 2010 | 02:04 PM
wmckeenster
Just ordered 2 sets...Thanks, need them fast so hope shipping is as swift as your reply.
