P0430 Catalyst System Low Efficiency Bank 2 Code Back
Old Aug 4, 2010 | 10:52 PM
Vette Nut's Avatar
Vette Nut
Default P0430 Catalyst System Low Efficiency Bank 2 Code Back
Well i thought after i cleared it a week ago i was ok. But a week later and 125 miles later its back. Might be a bad 02 sensor. I hate taking it to the dealer. About 2000 miles ago i added a NPP exhaust to the car. The flaps are open all the time. Wonder if that has anything to due with the code
Old Aug 4, 2010 | 11:00 PM
achilds's Avatar
achilds
There is a TSB on this and it involves having your ecm reflashed. Leave the code on and go to the dealer.
Old Aug 5, 2010 | 10:02 AM
Vette Nut's Avatar
Vette Nut
Can you send me the link for that, or give me the number ? Thanks
Old Aug 5, 2010 | 10:39 AM
achilds's Avatar
achilds
#09-06-04-011A: Malfunction Indicator Lamp (MIL) Illuminated, DTCs P0420 and/or P0430 Set (Reprogram Engine Control Module (ECM)) - (Apr 3, 2009)
Subject: Malfunction Indicator Lamp (MIL) Illuminated, DTCs P0420 and/or P0430 Set (Reprogram Engine Control Module (ECM))
Models: 2007-2008 Chevrolet Corvette ZO6
2009 Chevrolet Corvette ZO6 Built Prior to VIN Breakpoint 95112736
with 7.0L Engine - RPO LS7
Please Refer to GMVIS
Old Aug 5, 2010 | 11:09 AM
Vette Nut's Avatar
Vette Nut
Thanks, i found that one but i have a 2006 with the 6.0 engine so i may be out of luck
Old Aug 6, 2010 | 11:14 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
It's very likely an 02, but in the unlikely chance that it's a cat, they are covered under the Federal Emission Warranty for 8/80
Old Aug 6, 2010 | 10:09 PM
cyclerage23's Avatar
cyclerage23
swap your right and left rear 02 sensors, if the code changes, its the sensor, if it doesnt, its the cat.
Old Aug 7, 2010 | 10:58 PM
Vette Nut's Avatar
Vette Nut
bump
Old Aug 8, 2010 | 02:51 AM
djbrun's Avatar
djbrun
I had NPP opened from day one, not a problem. As mentioned earlier it sounds like either a rear O2 or a cat. I don't take my car to the dealer anymore and it only has 7500 miles on it, so I don't blame you there. You can swap the rear O2's and see if you get the code for the other bank. If you do you need a new O2 senosr, if not then it looks like the cat which would be covered for the federal emissions time period.
DJ
Old Aug 12, 2010 | 01:12 PM
h8bumps's Avatar
h8bumps
Has anyone swapped their O2 sensors after getting this code?
Looks like the TSB is for Z06's only. I have an '08 convertible.
I started getting this code a few weeks after putting headers on. I've cleared it a couple times, but it keeps coming back. I know you can tune it out, but I'm wondering if it might be the O2 sensor itself. If I get motivated enough, I might get under the car and swap sensors, unless someone else has done this already.
To P0430 Catalyst System Low Efficiency Bank 2 Code Back
