Gas pedal won't work- Reduced Engine Power, Service Active Handling, Service Traction
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try disconnecting and reconnecting the accelerator ped switch and see if your problem goes away.
BC
BC
The new pedal resolved the issue. I plugged it in and the car ran fine immediately and I drove it down the street to Advanced Auto Parts and cleared the 2 codes I posted initially and the CEL went away.
Josh
If you're getting the reduced power error randomly, sometimes it's the throttlebody if you've got a ported one or any other mods.
Ive gotten a few different errors. Most concerning apps A/B or D/E voltage correlation problem as well as one that says minimum throttle position not learned. I have stock throttle body.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What did the APP sensor cost you new?? This may be something that needs to be purchased before it really goes bad. Do you get a new sensor or the entire peddle??
ON HAND READY SPARES!
May have to get Gene Culley www.gmpartshouse.com to send me one!
Bill C
Bill C
Bill C
Bill C
Josh
I can't imagine getting the P2138 code and have a new pedal not fix it. My only next guess would be a problem with a wire/connector at the pedal. Can you do a little investigation with a multimeter to check the wires and connections inside the plug?
#33
Josh
#34
Bill C
Bill C
I got a take off pedal from someone who put on the elite engineering one for $50. Gene has them for ~$70
#35
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Female electrical connector pins have a small metal tongue that makes the connection with the male pin. If that tongue bends or relaxes, it causes an intermittent connection that can be effected by vibration. heat and or cold. Heres an example of a C5 wheel speed sensor female pin that is bad. The tongue is completely compressed and the male pin, if inserted into the female pin will literaly fall out if tipped down:
The connector on the LEFT is new. The one on the RIGHT is BAD:
I use a male pin that I extracted out of a switch to test the grip of the female pins. Thats the only way to properly test them. There should be a nice firm grip on the male pin when inserting or extracting the pin:
Check the APP connector for damaged female pins.
BC
#37
similar but different
I have an 05 m6 and i've been geting a "dead" pedal for a few weeks now. Out of the blue when slowing for a light the idle drops to 500 and I loose throttle response, I shut it down & restart it and it's fine until the next time if feels like acting up. I have also checked voltages & grounds and found nothing even with the t-body so today I swapped the gas pedal $100 and I'm hoping that this gets it.
#40
Moderator, Tech Contributor
Received 2,124 Likes
This is a 10 year old thread...hopefully the OP solved his issue by now !!!
