What tires are you running up front? How do you like them? Any reccomendations? Thanks.
chris... i have ran a few diferent type drs and have always had a problem with handling at higher speeds and on the interstates with tractor trailer ruts, i have put skinnies on the front, and belive it or not handling is great, but i havnt tried to hit high g's on turns
Yeah Im looking for something that will still allow some pretty quick turning. I bet that would get pretty adventurous with skinnies up front your a brave man.
Sorry for the hijack, but what skinnies are you running? I have a set of gto rims I can use but don't want to use the tires on them...
Im running the 305/35/18 MT et street 2's.
i ran those rears with 245/45/17 sumitomo HTR Z II's in front.
Originally Posted by Joe_G
I see they make 17's that's cool.
Yeah definitely avoid running the tires ('spares') that come on those rims if ya can, I know some who have done it and they survived but I still wouldn't recommend it. Both M&H and Hoosier make 'highway safe' 17" radial skinnies that will fit those GTO spare rims.
I run the stock runflats up front for the safety of a runflat. Rears are MT Et street 305's. In general, you will be hard pressed to find a front street tire that cant outhandle a drag radial in the rear. You will not have a dangerous situation unless big water is in your path.
I'd recommend not running a runflat with a DR in the rear as the stiff sidewall only increases the swaying feeling in any high speed manuevers you encounter. The softer sidewall of a non-runflat will make this less dramatic in my experience, if you're gonna run DR all the time. If you're not wanting to sacrifice cornering, I'd go with Nitto R2s.
