speed chip
Old Aug 16, 2010 | 11:05 PM
dennisdlj's Avatar
dennisdlj
Default speed chip
Am I to assume that there is not a chip in my 2010 Grand Sport Convertible Corvette that will not shut me down going over a certain speed??? Do all cars have this? If so, can it be disabled?
Old Aug 16, 2010 | 11:11 PM
tjwong's Avatar
tjwong
Your GS should not be speed limited, well not until after 200mph. There are no longer replacable chips in these cars, there hasn't been since after 1993 unless you had a 94/95 ZR1 in that case there was a replacable e prom. All C5s and C6s had flash programmable PCMs that has on board flash memory chips that are not removable.
Old Aug 17, 2010 | 10:36 PM
Streetk14's Avatar
Streetk14
Yes, almost all modern cars have a top-speed limiter or speed governor (whatever you want to call it). The auto manufacturers set it to reflect the speed rating capability of the OEM tires that come on a particular car. For example, a Corolla comes with "S" rated tires, that are not certified over 112 MPH. Toyota sets the limiter speed accordingly.
The C6 runs on (Y) rated tires that are good for 186+ MPH. There is no speed-limiter on the C6 as far as I know. Should be drag-limited to around 190 MPH.
Andy
Old Aug 18, 2010 | 10:15 AM
dennisdlj's Avatar
dennisdlj
Andy, thanks for the information. I really appreciate it.
Old Aug 18, 2010 | 03:15 PM
VET4LES's Avatar
VET4LES
I don't know about the GS but my 2005 LS2 shuts the fuel pump off at around 6700 rpm. That can be tuned out or changed.
To speed chip
