C6 stock brake upgrade
Old Aug 26, 2010 | 02:34 PM
JohnGaz's Avatar
JohnGaz
5th Gear
Default C6 stock brake upgrade
I know that several posts have discussed on this topic however, I didn't see too much detail on specifics such as available stock size rotors either slotted verses drilled and what brands, and pads either ceramic verses not. I was planning to stay with the stock calipers just upgrading the rotors and pads due to my venture into auto crossing. I found that the stock rotors were beginning to worp due to heat so I thought I could find a better system without spending big money.
Any thoughts..........
Old Aug 26, 2010 | 03:54 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
http://forums.corvetteforum.com/auto...e-learned.html
Old Aug 26, 2010 | 04:13 PM
johnodrake's Avatar
johnodrake
Moderator
Lots of mythology about warpped brake rotors. Here is a great read on the subject.
The "Warped" Brake Disc and Other Myths of the Braking System
Old Aug 27, 2010 | 12:08 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Before going to AP Racing brakes I used the stock (solid rotor) C6 brakes with stainless steel brake lines, Motul 600 fluid and Performance Friction C5 Z-compound pads. They worked fairly well at the track. You can also go with stainless steel caliper pistons. I knew one guy who used the Eradispeed rotors on his C6 which he liked. Doug Rippie Motorsports was a good source for brake upgrades...you might give Randy a call and talk with him.
Old Aug 27, 2010 | 09:20 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
What are your intensions, just auto x or track time too? Also are you looking for a pad that is quiet or do want true performance?
To C6 stock brake upgrade
