cam for LS3-headed 402?
Opinions?
If you want a more aggressive cam for more power and have less interest in maintaining stock like driving manners, contact PatrickG. More duration can be used and still stay under the 4 degree overlap comfort zone. I would avoid the ubiquidous big duration/naraow LSA cams as none of them have made any serious increase in power over the results I've seen with a 230/117 range cam.
By widening the LSA to extend the power band, what effects does it have at lower RPM? This will be primarily a street car, and I've always been a big fan of low rpm torque.
If you widen LSA and increase static compression it does nothing to the low rpm power since dynamic compression remains close to the same.
Wide Exhaust durations, for those that emply them increase overlap by 1 point for each two degrees added. The gains from this are solely for high RPM power over the HP peak....it makes the power band extend higher (so does a wider LSA in that it extends where the HP peak actually occurs with a given intake duration.
To put this into real world facts, I used a 230/242 as the first LS3 cam and it made 3HP more at the HP peak of 6300rpms over a 230/234 do for the extra 4 degrees overlap, there was no real power gain so why deal with the drivability. Yes people that are great tuners can make such cams liveable but if you start with less overlap, that same tuner can have that much better driveability. Im not a cam expert but thats the scoop on a very specifc use with a real cam in a real car. Narrower LSA's are a help for low end only in that if you cant bump static compression, it closes the intake valve sooner and makes more low end TQ. LS3 cars have limits of how much compression can be increased due to limited intake valve clearance. As proof of my position, to date the best result I have seen on a stock LS3 headed car is only single digit improvements over the 230/234 cam. You decide if you want a ton of overlap for the added few HP up top. Just as a revelation, I have sen a 238/252 112 LSA make 480rwhp on a 403 stroker. You tell me whats wrong with that picture. Aitqik's cam was a 236/242 114LSA and it made 499/480 on his 403 with ETP 215's. So if a 230/234 117 makes 500rwhp its doing fine and it will idle at 700rpm with almost no lope.....at -2 degrees overlap its actually a great FI cam.
My car is running 17PSI boost with cometic MLS gaskets and I have used them exclusively now for 8 years on corvette builds and we are talking a lot of cars. I never had a failure or a leak.
When tuners make cam recomendation like Patrick G, understand that he is using some really informed tuning skills and many shops out there really arent on that level. I have been in cars with that 230/234 cam at 4 degrees overlap and it drove like stock while other tuners couldnt get it to not buck and surge like an electric bull so you have to take into account the level of tuning expertise that is available to you. I am middle of the road. All my cars drive great but then I dont use mad huge cams.
I would defer to Patrick's expertise as I know of his work over past years and he has influenced my own path in modding. His being here is an asset to the forum but keep in mind your tuner may not be on his page of skill.
FI benefits from having minimal quench distance so thinner gaskets are better for detonation suppression. As far as boost and high power, my cometics are fine with 17PSI and a 75 shot on top of it. I know Mr big's car used stock LS2 gaskets and he was at 15psi.
If anyone is afraid of using MLS gaskets, a .040" is available for the LS2 from felpro and its a great gasket. Tony Mamo at AFR swears by them.
The info above is good and Im sure it generally works with trick flows and AFRs but the LS3 heads dont react well to overlap (due to reversion I suspect). I see lots of LS3 head 403s over on LS1 tech making 480rwhp with bigger durations and tight LSAs while stock head LS3 376ci with a 227 to 230 intake duration cams make in the 490's to 500 pretty consistently. Most of the stroker LS3 head builds tend to use ported LS3s so its not apples to apples.
Is it that the 403 shrouds the intake valve due to its 4" bore? I get the undervalved point but Im not sure how the 2.16 intake valve on a 4" bore fits in the tech point.
One point is that the 230 117lsa would run more static compression due to the lower dyamic compression.
Pat, are you getting, or did you get a corvette? Good to see you posting here.
For what it's worth, the added cubes require more overlap to maintain the same driveability and power per cubic inch. Not excessive overlap, just an appropriate increase in overlap. That's why I only recommended a 4 degree increase in overlap on the 402.
Tjwong, did you ever dyno the car with the 224/236 cam? Your description makes it sound very appealing.
1 or 2 posts doesn't explain much about what is going on. Calling the guy and getting him to explain what's going on and why he's choosing certain specs is far more valuable.
He's a good guy to talk to and will answer any and all questions.
He recently specced me a 238/242 110lsa on proprietary lobes for a max-effort cam only setup. Explained everything to me and I was in communication with him for an additional week about how to specifically set my entire valvetrain up to match it.
