Service column lock WTF???
-Gabe
Also get the sensor for Active Handling fixed while they are in there, I think there was either a recall or a TSB.
I replaced the column lock myself and it works every time now. Here's a thread on my ordeal. http://forums.corvetteforum.com/c6-c...lumn-lock.html
I'm positive the dealer replaced the actuator on my C6 because the unlocking noise was different with the original actuator. I think it now sounds the same as the original, and coincidentally it now still gives me SCL messages. How does the actuator module fit into this whole mess?
I wouldn't worry about it. I have a feeling that is a default error when the car is having an issue starting...
Or maybe the column lock needs to be replaced and it's just a coincidence that you also need a new battery. Yep, I'd be skeptical.
Maybe you already know...
-- When you park, you must shift to reverse before shutdown or you'll kill the battery.
-- C6 charging system is marginal. It takes about a half-hour of driving to replace the energy used to start the car.
-- C6 battery is small. Infrequent use and/or short trips will kill it. And once it dies, it never fully recovers (less of a problem with if you have a deep-discharge battery like an Optima Yellow Top).
-- A weak/dying battery can cause lots of weird electrical problems.
-- A good battery maintainer is a VERY wise precaution especially for a weekend driver. This will keep your battery charged and extend its life.
-- Be sure your new battery is well-charged.
-- Some 05's suffered from Dead Battery Syndrome. It's fixed by a reflash at the dealer. This is old news, so yours was probably already fixed. Just a heads-up.
More than you'll ever want to know about battery-related issues:
http://forums.corvetteforum.com/c6-c...ocked-out.html
It is NOT the module it is the lock itself.
To get it to start until you get it fixxed - disconnect the battery it will reset the column lock
and it will probley start. Mine did.
