replacing rear side marker
Hi, I need help replacing the rear side marker on my 07 vert. I cant see a bulb socket on the inside in the trunk and I dont want to mess something up. Thanks
Jeff
Jeff
St. Jude Donor '11-'12-'13-'14-'15
You need to remove the outer tail light.
One screw in the top and the tail light falls right out.
Then you can reach in and get to the side marker light.
If you are just replacing the bulb, the socket/bulb just twists out.
If you are removing the entire assembly, there are two tabs that you squeeze, then the side marker pops out.
Couple of tips after you have the tail light out-
When you reach in, make sure you don't knock off the clip that your tail light screws into. Sometimes these are loose and will slide right off.
If you do lose it, it's a common little part that you can get at Autozone/etc.
If you have LED's instead of regular bulbs in your side markers, remove the bulb/socket carefully. Many LED's do not fit very tight and can fall inside of the side marker housing.
Again, not a big problem, you just have to remove the side marker and shake the LED out.
