Professional installs/tunes
Install: 6 hours at $90/hr = $540
Dyno time (required for tune): $300
Tuning: 2 hours at $150/hr = $300
Total: $1140, which is almost as much as the cost of the parts ($1450)
I could probably get it installed by a mechanic for half as much (the quoted price on the parts is not contingent on them doing the install), but I'd still end up spending $600 on the tune.
Randy
Last edited by Fissile; Sep 1, 2010 at 11:38 AM. Reason: spell check tried to correct dyno
You don't need a dyno tune. After all, guys use mail order tunes all the time, and those aren't dynoed on their car, right?
I'm not advocating a mail order tune, but a competent tuner has a repertoire of previous tunes, at least several with your engine/mods. And hour on the street, for tweeks, and you'd have a very reasonable tune.
Now, you may well leave some top-rpm horsepower on the table! And you won't know your power output that day. I'm just sayin . . . the dyno isn't strictly necessary.
ECS mail order tune http://www.eastcoastsupercharging.co...ynotuning.html
I just installed the Kooks with X-pipe and SLP exhaust and also added a Honker CAI last night. Heading to CarTek in Jersey Fri Morning for the tune and dyno.
If you can pick up some extra heat tape to ensure all 02 sensor wires are away from heat source.
Those prices are UNREAL!
Hell,, have a mod party and get the job done for little or nothing. Heres how I did mine:
Jack and remove the old stuff install headers and un-jack,,,,,, total 4 hours.
ARH headers are your best bet for fit and performance!
A dyno tune is not necessary right after the header install.
Shop around for a good tuner who will perform a good on the road wide band tune for over all best performance. Most decent wide band tunes cost $350-$450
$600 for a tune is INSANE!
Remove the plugs or risk this!!!!
Bump ONE plug and that will happen! Trust me!
BC
If you decide to do so, please remove the spark plugs like others have said. We charge $400.00 to install the headers and then $550.00 for the tune. BUT our tune is a street tune, not a dyno tune. Much better performance afterwards and it also takes longer than 2hrs to tune a car properly.
Chris
