How Much Tire Does One Need?
I can't recall which race car it was but not so long ago there was one car running identical size wheels/tires on all 4 corners. I'm sure the car was extremely well balanced and the theory was they'd sacrifice a bit in a straight line but more than make it up in the corners. If you're a drag racer you want to run wider rear tires and 'narrow' front tires.
I'm no expert but IMO if the car is primarily used on the street I think the stock Z06 wheel/tire sizes offer a good mix of performance and 'roadability.' There is no one perfect wheel/tire size...it depends on what you do with the car, the car itself, your own driving style and what you want. Adjust accordingly.
Thanks for the input!b
I've been reading some car testing and I found it interesting that even with the widebody setup of the GS (which incorporates the wide Z06 stance), in some tests it could only pull off .96g -.98g.
Then in other tests the base coupe with Z51 has pulled .98g and even 1.00g. I know driver variances along with weather conditions all play a role in those numbers.
It made me think. Why can the Z06 pull off a constant 1.00g+ and the GS which has the same tire size cannot pull that number?
My conclusion is that weight (the GS weighs a couple hundred pounds more) and the HP/Torque of the GS is substantially less, therefore it cannot pull through the added loss it has due to rolling mass. The larger the tire, the more HP it takes to turn it and the more rolling resistance one gets.
Therefore, like you reiterated, there is a "sweet spot" where just enough tire, combined with suspension engineering, weight, HP, give the car its perfect cornering capability. Slapping huge tires on the car can actually slow it down and give it poorer handling capabilities.
Straight line acceleration for cars running 9 sec passes almost never run a 345 tire out back. Most of them run a 275 wide tire to do it it because tire side wall rather than width is the primary traction component.
The C5R and C6R cars run 18" rims rather than 19" for optimum handling too.
Tire width is not as important to handling or straight line traction as is the comination of other factors.
Disclaimer is that is super simplified, but the fundamental test of whether you need more or less tire is in the temps v. mfr recommended temp range.
The ZR1 uses a 19"f - 20"r combo
The Acura LMP car had front & rear matching tires
The McClaren F1 uses 17's all around.
Ferarri Enzo uses 19's all around
Lamborghini Gallardo: 19
Since sidewall is so much of the equation for acceleration, there has to be a balance for traction vs handling. While it can be argued that sustained high speed may be better with lower profiles, racing that requires a wide range of speeds and thus acceleration would then need a compromise for average performance. Since the corvette's main issue is traction limited perfrmance when you mod, the median of 18 is the best compromise. I have driven cam only cars that cant hook in 1st or 2nd on a 305/20 100 compound (nitto) tire while a 305/18 100 compound nitto hooks to 500rwtq. 20" then goes the wrong way. I would imagine the 20" thing is for bling and would be the first thing I would get rid of if I obtained a ZR1.
I doubt the C6r would use a lower profile out back regardless of rules. Your assumption is just that though. Perhaps Lou Gigiotti will chime in to clarify as he builds a real race car and would know what it takes for all around performance on rim sizes.
In any event please dont say that because GM used 20's on a the ZR1 that it validates that they are the best for performance. I dont think I can handle "GM does it best" today.
But I am long winded
Without spinning this way out, what any real racer wants to do is minimize unsprung weight. With the uprights on the new Vettes, you can NOT go any smaller than 18" diam wheels, so that is the lower limit. Going with bigger wheels = more unsprung weight, so to me the smallest wheel that fits over the brakes (or for the Vette brakes and uprights) is the best wheel diam. Width then is selected by tire temps.
The C5s and C6s (and all sorts of "performance" cars - and yes that is in quotes) have bigger diam rears than fronts because that appeals to the average Joe for some reason. Bigger somehow now = better, so the ZR1 adds some more weight to each corner because guys want to say they have 19/20 combos - absolutely beyond me but GM is out to sell cars that perform great but mostly sell based on appeal, not necessarily performing to the maximum. That is why the Vette looks like it does and the aftermarket exists for those that want to maximize what they bought based on appeal. In guy terms, you got a pretty hot chick, but she could use a boob lift and drop a couple more pounds to be stunning
Looking at the Lambo stuff, the Gai and Murcs are for guys with big pockets, not necessarily track, but the Lambo Murc LP670-4SV uses 18s front and rear that would just barely fit over 15" rotors - so their top model they claim is oriented to racing uses the smallest wheel that fits their brake package.
I agree that on most cars, even old muscle cars, 18s all around look good. I do like 17s with a bit more sidewall on muscle cars, but 18s are maximum for any car IMHO. The only thing I don't like about my Vette is the way the tires look like they belong on a forklift, everything else just looks awesome. And does the typical owner ever need a 14-15" brake setup... NO
12" rotors with 4 piston calipers and good pads are more brake than 90% of drivers would ever need frankly.I have 12" diam rotors and 4 piston Brembos on my race car as that is all it needs for my purposes - I used 16" wheels ONLY because I could get smaller diam tires (so shorter sidewall) and overall lower weight at wide widths v. the 15" even. Lower mass moment to accelerate and brake is a further bonus. Compared to an 18" combo for my car I save ~20-25 lbs PER CORNER in unsprung weight with that combo if you consider the larger tire weight, the larger wheel weight, the larger rotor weight, and the larger caliper weight. If you don't need it, that is the answer, don't add it.
Hence why selecting components for tracking isn't a simple consideration, and surprisingly, there is a lot that goes into selecting tire sizes when you are allowed to do so
Take this is coming from a guy that is a bit of a 1%-er, I don't DD the car and only make a change to maximize performance. If I put race wheels on my car down the road, I will consider 18x11 fronts and 18x13 rears with 315/345s. My tires would be Hoosiers given I drive the car periodically around town or to work and never in the rain, or on the track here and there. If I take a road trip, the stockers would go back on.
I wonder if the Grand Sport widebody stance is more about bling than performance. I would be curious to see a back to back test with the same driver, same tire design, one on a 2008-2009 Z51 coupe and then with a 2010 GS. Which would truly handle better if driver, conditions and tire design were all the same.
I've read reviews where the GS only pulls .96g - .98g and then the Z51 base coupe is pulling .98g - 1.00g.
It would be interesting to see the results of said test. Is the GS widebody just more rolling resistance, on a heavier car?
Since the two have the same engine, the lighter car will be better on the track since lap time is a collection of averages, so if the lighter car can corner 0.1mph faster in every turn, and slightly better HP/wt ratio means juuuust a bit higher speeds in the straights, the lighter car will win. So to answer your question, based on your scenario the lighter car should have a slight advantage in my guesstimation.
Now, if the two cars are wheel to wheel racing, and the GS can brake later due to better grip and larger brakes, then things get more interesting. HP being equal, even if the GS is sliiiiiightly slower thru the corner and on the straights, on a typical road course it won't matter because the GS will dive in deeper and pass into the turns, then simply block the other car that can actually carry a bit more speed thru the turn. In the straights, the GS beats it out of the turn, and even if the lighter Vette with that little bit more power/wt ratio can get up beside the GS, he just brakes deeper and maintains the lead at the next corner. Often, both cars run slower lap times than they would in an independent timed lap test because battling for position won't equate to perfect lines. But in my best guesstimation, in this scenario the GS has the advantage.
To end a bit tongue in cheek, the GS will win no matter what because the dry sump will keep the engine oiled and in one piece
It's all bench racing at this point, but a fun convo nonetheless
There conclusion was, at least on that BMW 325, was that anything bigger than an 18" wheel was an exercise in diminishing returns. So basically what others above have said, bigger than 18 = show not go
BUT, in reality, most people buy wheels for show not go anyway.
1. If they were all the same diameter, then the sidewall becomes a second variable (wheel size is one) and was taller on the 16" than the 18" and that will hurt performance. As noted before, shorter sidewall is better for the track (to a point, all things have limits). The tall sidewall tire would roll over and run on the sidewall v. optimal contact patch of the tire and howl and slip. This was very evident on my F150 Lightning pickup I used to have - I would track it for grins periodically and I would scrub down almost an inch on the sidewall
2. If the tires all had the same sidewall height, then the overall diam becomes the second variable and the overall final gear ratio is changing between the tires. For my race car, on one of the local short tracks I use the 23.5" diam rear tire as it nearly optimizes my gearing for the course without opening the trans. On the other track locally I run the 25.3" diam (note the 3 and 5 swap). The ~2" larger diam tire gets me just a few more mph at top rpm, which works better in the main straight (don't need to shift to go only 300ft more and downshift again) and I can get thru the esses in one gear as well and go deep into the next turn.
So, for #2 we could deduce my car would be slower with the 16" wheel and 23.5 tire v. an 18" wheel with 25.5" diam
True tests only vary one variable at a time, unfortunately that is WAY easier said than done, and magazines like easy articles and sales, not science, so they draw conclusions at will
To only vary one of the variables (wheel diam) they would have had to hold sidewall height constant and re-gear the transmission each time they swapped overall diam.
I wanted to reiterate their test here for discussion purposes, 325's & Z51/GS's aren’t both apples.
To only vary one of the variables (wheel diam) they would have had to hold sidewall height constant and re-gear the transmission each time they swapped overall diam.What's your take on just normal street driving with occassional high-speed maneuvering. Is a dry sump needed?
Here is that same thought being expressed by a car reviewer:
"On hilly, twisty Kentucky roads, the Z06 couldn't hide its substantial, lane-filling width, which hindered the hustling cause and held back its lane-change speed, too"
I've been in cars that had narrower tires and the car felt more nimble and "zippy". With the GS, it felt big. If the driver felt this way in a Z06, how much more with a GS which weighs a couple hundred pounds more than a Z06 and doesn't have the same power to weight ratio.
