Memory Seat Problem!
Old Sep 7, 2010 | 06:05 PM
tonypro99's Avatar
tonypro99
Default Memory Seat Problem!
Hey All;
I seem to be having a problem with the Driver's side mirror and Seat retaining it's present position that I set it too! I have tried with both Key Fobs and they both seem to go to a different position then what I set it to.
Whenever I exit the car and and come back in it moves to a position "IT LIKES" and not the one I saved. I was wondering if anyone has a resolution for this issue?
Old Sep 7, 2010 | 06:28 PM
RicK T's Avatar
RicK T
I'm not clear on what's happening or what you've done so I'll just say start from scratch with setting the memory positions for each FOB as described in the owner's manual. If that doesn't fix it raise the seat up as high as possible and check underneath to make sure the wire connectors are tight and locked.
Let us know.
Old Sep 7, 2010 | 06:36 PM
tonypro99's Avatar
tonypro99
Dear Rick;
The fobs have been programmed for the seat setting correctly and I took out the seat completely to diagnose the problem and check and cleaned all the connections. The only thing I can think of is that the Memory Seat Module has gone "Loco" lol???
Old Sep 7, 2010 | 06:54 PM
RicK T's Avatar
RicK T
Originally Posted by tonypro99
Dear Rick;
Ah....understand now. Then the module is definitely a possibility. A few have been reported here but doesn't seem to be a huge problem. Looks like you need a dealer trip. Good luck.
Old Sep 7, 2010 | 08:35 PM
NEVERL8's Avatar
NEVERL8
My "loco" seat and memory system was finally diagnosed as a chafed wire in the wiring harness that was interferring with the 5V reference supply of the microprocessor in the seat control module.
Old Sep 8, 2010 | 02:45 PM
tonypro99's Avatar
tonypro99
How would I go about testing the wiring harness to see if there is a chafed wire? Any tips on this?
To Memory Seat Problem!
