07 ZO6 problem with hatch button
Old Sep 11, 2010 | 05:03 PM
lewis1989's Avatar
lewis1989
7th Gear
Default 07 ZO6 problem with hatch button
I have a 07 ZO6 and when I went to hit the rear hatch button on the rear fascia today it did not work. Just used it the other day and it worked fine. The car only has 5900 hundred miles on it. I haven't tried checking the wires yet to see if one might have come unhooked or not. Thought I would see if anyone else has ever had this problem before. Thanks
Old Sep 12, 2010 | 11:04 AM
ch47d1sg's Avatar
ch47d1sg
Have had similar issues issues and it was usually related to the FOB and not the wiring... Rear button will not work if the car does not 'see' the FOB. See if taking it out of your pocket and changing where it is helps first..... I use the rear button all the time
