Brake Problem
Old Oct 4, 2010 | 01:45 AM
Bkbulldog's Avatar
Bkbulldog
Default Brake Problem
I recently had the brakes changed and have noticed that it takes alot more pressure on the brake pedal to stop the car after having new brae shoes put on does this make sense? Idk what the problem is? Is it low brake fluid? How can I check? any ideas?
Old Oct 4, 2010 | 02:47 AM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Did you bleed the brakes properly with a tech tool that cycles the ABS? Sounds like there's air in the lines.
Old Oct 4, 2010 | 08:38 AM
Bkbulldog's Avatar
Bkbulldog
Yeah I can push the brake down kinda hard and it is not stopping like it is meant to stop it will kind of glide to a stop.
Old Oct 4, 2010 | 08:54 AM
HD_Rider's Avatar
HD_Rider
If the calipers were not replaced, there should be no air in the brake lines since the system was not actually "opened."
Did you switch to ceramic pads or some other medium other than the original OEM pads? A different brake pad material can result in a different feel at the pedal.
Did you bed the new brake pads properly? Bedding the pads is critical to optimum performance, low noise, and long-wearing components.
Old Oct 4, 2010 | 10:06 AM
Bkbulldog's Avatar
Bkbulldog
I have no clue what they did? I just felt the brakes and they feel not that strong at stopping the car. Right now my truck feels like it has way more stopping power. I can push the brake down pretty hard and the car will stop normal when it should be coming to a screeching halt.
Old Oct 5, 2010 | 07:09 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Harder pads can require more pedal pressure. Race pads require more pressure until they are hot. What did you have before/after?
Old Oct 5, 2010 | 06:36 PM
Bkbulldog's Avatar
Bkbulldog
Ummm OEM to some brand sold at auto zone?
Old Oct 5, 2010 | 07:34 PM
timd38's Avatar
timd38
You could probably get help, but your profile is blank, so they can't offer since they don't know were you live........
Old Oct 7, 2010 | 11:31 PM
Get U 1's Avatar
Get U 1
2nd Gear
hello everyone im new to this i recently bought a 2009 c6 corvette with the z51 package,
i seem to be having some brake trouble when i park my car for a while my brakes go dead and when i start up it regains pressure i think its a booster problem however it gains pressure to the point where it feels like the brakes are dragging. can anyone give me some advice on how to solve this problem asap.
thank you
To Brake Problem
