Best cam for the LS2 heads
Advanced induction is the place to go get your 243's done. Over on the gto boards AI ported 243 heads are on some of the fastest gto's. TEA (total engine airflow) is probobly just as good. I only give AI the nod because they designed that port originally for gm. They know the head. Both places will do you up good and cost about 1200. I have talked to both and they both told me when you already have 243 heads there is no point in buying an aftermarket casting, Heard it from brian tooley himself. Ask ecs how they like the TEA 243's.
I thought stock head LS3's were getting 500 rwhp with a 230 spin cam and stock intake manifold? 6.2L v. 6.0L, but it should be close to that?
The additional cubes help a lot.
St. Jude Donor '08-'09-'10
Just one more thing. The stock or reworked 243 Heads will have poor resell
value. By the time you are done you will have spent close to the cost of the TF 225's. You can sell your stock heads and add to that to get the
TF's. They will make so much more power. I got about 50 rw from the trick flows and the 243's had patriot springs etc. There is no comparison as the TF's and the FAST 102 took me to 507 RWHP.
Here ya go man, gto with AI heads through a stall. 503rwhp
http://www.ls1tech.com/forums/dynamo...st-2009-a.html
Another gto with AI ported heads and vrx5 cam put down 494rwhp
The tfs heads are a very nice piece and so are the afr 230 heads but both come at a substantial price increase. The tfs require roller rockers which brings the cost up to 2900 and the pat g afr 230 head was custom tweaked and cost 3600. They are not worth 2k more.
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
From a cost vs. power increase perspective, its hard not to go with aftermarket heads. However, you can make the mistake of going with the wrong ones. The other day, I learned of a LS1 Corvette with big port stage III heads that made 20 less RWHP than a set of smaller, ported GM heads. Bigger heads are not always better. Velocity is the name of the game and to maximize torque and power, the port size has to be right.
Also, the hp difference between and LS2 and LS3 has alot to do with the LS3 heads, not so much 0.2 L, IMO.
Is the LS3 (823) head really producing 500rwhp stock with bolt ons?
I looked the other day at the LS3 heads and seen that I could
pick up a set new for around 1600 and I just looked at some used
sources and found them for under a thousand.
I was hoping to stay with the 243 castings, and may still do that
but I don't want any regrets later after the build is all complete.
Keep the Information coming, I appreciate all input.
Riggs.
Riggs.
St. Jude Donor '09
I'd listen to Spin. If Spin told me I was spelling my name wrong I'd probably have to change my name. There are those that know what they're talking about, and then there's Spin.
Spin's probably the only person I've never met personally that I'd leave my Corvette with. He drips of professionalism and integrity. He stands behind any work he's ever done, and that's something missing from almost everyone.
San
San
Riggs.
Riggs.
Spin himself above seems to think there are better heads, but with results like Andrew's car, I don't see the problem
http://forums.corvetteforum.com/c6-t...p-records.html
Originally Posted by SpinMonster
The last forum member to use my 230XFI/234XER 114+2 got 504rwhp/461rwtq.
It was an independent tuner and install.
At 4 degrees overlap, its a great driving cam.
Cam only (no head mods) with bolt-ons.
Considering the large price difference between off the shelf LS3 heads and aftermarket, I don't see much value of upgrading to aftermarket and only gain a few hp. Maybe Spin will clarify this.
#33
Received 2,054 Likes
and for those that dont know, trap speed is an indication of power made with little driver skill affecting it unlike ETs which has a good indication of driver skill. Both good and bad drivers will have nearly identicle trap speeds so its a good indicator of average power being made. (The only variable being DA)
#34
The ls3 head is awesome but many people screw up and use 1 7/8 headers. The 1.59 exhaust valve in the ls3 heads likes 1 3/4 headers better. If you notice some of the fast spin cam cars are using 1 3/4 headers.
#35
Spinmonster designed a 230 cam for AndrewZPSU's 08' LS3. Stock LS3 heads, just cam, headers, cai, CB and DR's and he ran 11.1 at 129 mph (504 rwhp). Great drivability.
I read the long thread about LS2 VS. LS3 heads and came away thinking the LS3 style head shines on a larger displacement and the 243 style head is tough to beat on a 4" bore LS2.
#36
I Have 243 heads enhanced by Performance Induction to LMR's stage 3R spec's, comp cams 54-459-11 (LSR) camshaft, Fast 90 unported intake with LG 1.75" headers, 6 speed tranny. Car layed down 487 rwhp & 440 rwtq thru 3.90 gears in the middle of the Texas summer. Very streetable, this cam isn't designed for max HP. Factory heads can perform for less money. If FI was in the cars future I believe aftermarket heads are better because of a thicker deck. I have no regrets. Just my .02 cents.
http://www.youtube.com/watch?v=jXfkePZR5bA
#37
I wanted to stop back in and say thanks for a the guidance. I will
need you help again in the future and hope that I don't become a
pest.
Thanks guys
Riggs.
pest.
Thanks guys
Riggs.
#39
231/239 is your cam design and since I am thinking of an EPS lob'd 233/239, I have to ask- How are the street manners? I know you say it's streetable but more input would be cool. What rockers and push rods are you running? What cai as well? What cc chambers?
With a 102, rockers, stout pushrods and a SD tune, I can see picking up some good power.
Thank you-
Jason
#40
Thank you-
Jason
Thank you-
Jason
Car sounds awesome at idle with some body shake, no driveabilty issues at all concerning the cam, and runs like a bat outta he!!.The RPS clutch is like a light switch. On or off. That took some getting used to, nothing to do with the cam. Again, I have no regrets and can only share with you the results of my build which I'm very pleased with. Good luck and hope this helps. PS- Best advise I can give you is seek professional advice, use internet forums for info only.
