brake options
Old Oct 11, 2010 | 03:27 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Default brake options
after 4 years my z51 brakes are about the bit the dust er not anymore
i would like to upgrade to something that will give me a noticeable braking performance, my car is not a DD and see possibly 1-2 track events a year, theyre just for fun nothing competitive
my cheapest option is upgrading my current z51 with hawk hps pads, 2 peice rotors, ss lines
pros: cheap/ easy (relative to other options)
cons: (still have stock calipers)
my other option is to purchase the brake system off a z06
positive: bigger brakes, 6/4 pistons, aestetics
cons: weight (each rotor is 10lbs heavier in the front and 2 lbs in the back), need to use spacers and studs to give proper clearance for the bigger calipers, heard bad things about the padletts and rotors cracking
last option is to go with z06 calipers/brackets/ ss line but use 2 piece rotors and carbotech 1 peice pads
pros: keeps original weight, best performance w/o spending 5-6k on a BBK
cons: price
i never ridden in a z06 so i cant comment on their brakes, does anyone have experience with any of the setups i mentioned?
Old Oct 11, 2010 | 06:26 PM
timsam's Avatar
timsam
I have a z51 and have two setups: Street and Track
Street: z51 brackets and drilled rotors with GM Ceramic Pads
HPDE Track: Base brackets and slotted rotors with Carbotech 12/10 pads: I use the base rotors cause they are a bit cheaper.
I think the performance on the track is great with the stock setup and upgraded pads.
Ive thought about your other options as well...but the cost and the other changes (spacers, studs or new wheels) made me stick with the stock calipers.
Old Oct 11, 2010 | 06:27 PM
gtmotor's Avatar
gtmotor
Do some research on the Z06 brakes... I was thinking about them at first but have changed my mind thanks to some feedback here and some of my own research.
If you only do 1-2 track days a year, I'd recommend upgrading the Z51 setup with a ducting kit (Quantum motorsports), better pads (I'm partial to Carbotech), stainless lines, and either Castrol SRF or Motul RBF600 fluid.
That'll be way cheaper and still should provide enough for you. It's what I'm planning on doing
Old Oct 11, 2010 | 07:06 PM
drivinfast's Avatar
drivinfast
+ on this, it stopped me at 200mph a bunch of times without cracking the stock rotors. do SS lines as well.
Otherwise bite the bullet and do BBK + new rims and widebody
Old Oct 11, 2010 | 07:29 PM
Robls6's Avatar
Robls6
Mike,
I'll take your Z51 caliper brackets if you decide to part it out. I want to put the Z51 rotors on my car. Let me know. I'm not really in a hurry.
Old Oct 11, 2010 | 08:33 PM
timd38's Avatar
timd38
Wilwoods are reasonable and will fit without getting new wheels by using a 1/4" spacer. ^ piston front and 4 piston rears. Car stops great!
Old Oct 11, 2010 | 08:36 PM
tpereira's Avatar
tpereira
I just installed the Z06 setup with DBA4000's, Carbotech Bobcats, and the goodridge lines... I should have made the change a long time ago. On a side note, anyone want to buy some used Z51 stuff ?
Old Oct 11, 2010 | 08:42 PM
timd38's Avatar
timd38
Take a look at this.
http://forums.corvetteforum.com/c6-p...cost-bbks.html
Old Oct 12, 2010 | 11:18 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
cons: price
I would be happy to help you. Please contact me at 216-780-8825 there are many options I can help you with. We sell ss lines and fluid also.
Z51 caliper xp10 front Xp8 rear ss lines cooling ducts SRF fluid and rotors would be my first bet before going to a new caliper. These work fine on the street and awesome on the track.
Old Oct 12, 2010 | 11:45 AM
Wayne O's Avatar
Wayne O
CF Senior Member
You're not really tracking the car so replacing everything might be way more than you need. From what I've heard the stock Z06 brakes aren't all that great. With relatively minor upgrades your OEM brakes can perform quite well. Even for street use I'd go to solid/slotted rotors; use more aggressive pads; install SS brake lines; use upgraded fluid such as Motul 600; and, possibly use SS pistons as well. With minimal expense you can vastly improve what you have. There are many sources but FWIW Doug Rippie Motorsports always had a decent selection of brake upgrades. Good luck!
Old Oct 12, 2010 | 11:55 AM
SinisterC6's Avatar
SinisterC6
Speedy
Originally Posted by timd38
ordered im going to make some custom cooling ducts as well
To brake options
