New products from Trick Flow
Old Nov 5, 2010 | 10:49 AM
tjwong's Avatar
tjwong
But why a .100" smaller intake valve for the new LS7 head? And .060" smaller for the LS3 head? Iam sure they have a reason but I would sure like to hear it.
Old Nov 5, 2010 | 11:04 AM
FUNTRUN's Avatar
FUNTRUN
would the smaller valves be for better velocity and more torque??
Old Nov 5, 2010 | 02:05 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Not sure but might give better PTV clearance as well
Old Nov 5, 2010 | 02:44 PM
tjwong's Avatar
tjwong
That for sure would happen with a smaller valve.
Old Nov 5, 2010 | 11:50 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Saw the eye candy at the Trickflow booth today.
The ports and chambers look like artwork!
Old Nov 6, 2010 | 07:55 AM
timd38's Avatar
timd38
Originally Posted by Joe_G
Saw the eye candy at the Trickflow booth today. The ports and chambers look like artwork!
I was drooling over them Tuesday. I was reviewing my head options and those appear to be the best out there once they are released.
Does anyone know the advantages of LS7 rockers?
Old Nov 6, 2010 | 07:58 AM
timd38's Avatar
timd38
Originally Posted by Dulimon
What duration and lift cams would be around the sweet spot with these heads? Have a good feeling I waited on purchasing heads. Are these the rumored 11 degree heads?
My understanding is that they plan to have a kit that includes a cam just like their LS2 550 kit they have today.
Old Nov 6, 2010 | 08:37 AM
Dulimon's Avatar
Dulimon
St. Jude Donor '10
That will be a good package for people. I already have a cam and wondered if it would be in the optimal range with the heads. I'll wait till ECS has the head specs and find out.
Has anyone heard of pricing yet?
Old Nov 6, 2010 | 08:51 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default Keep your reputation
I have the TF 225's on my LS2. Picked up 45 rwhp w just a bolt on. If the
TF Heads for the LS3 are anything like the 225's on LS2's then the LS3's
will finally win the HP race and probably reach 550 RWHP.
Old Nov 7, 2010 | 03:03 PM
HC Mechanic's Avatar
HC Mechanic
Do you have any charts you could post, w/before and after the 225's?
Old Nov 7, 2010 | 03:52 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Bigger valves don't necessarily make more power. The valve needs to be the optimal diameter for the head port and cylinder bore. A bigger valve on a head port which is designed for a small valve won't make any more power. Many times, it will make less.
Valves are simply plugs. Once the valve start opening, it is just blocking air flow. Also, a bigger valve is closer to the cylinder wall thus air flow will be restricted if its too close. This is called shrouding.
Old Nov 8, 2010 | 05:03 AM
C6-Q8i's Avatar
C6-Q8i
When are they available for purchase
Have been waiting for trickFlow for along time
Do u guys know how much these will cost?
