Strange electrical behavior...
Old Oct 20, 2010 | 09:58 PM
PJohnsonATX's Avatar
PJohnsonATX
Default Strange electrical behavior...
05 base. This morning car would not respond to hatch button press (on car) or FOB unlock request. Switched FOBs...same result. Upon using the emergency hatch key unlock, alarm started to sound and FOB began to work. HUD, DIC and radio were reset almost as if they battery were dead. Was able to crank car and drive away....
Pretty odd....any thoughts? Battery voltage looked fine today (between 13 and 14 volts.) No other issues since.
Old Oct 20, 2010 | 10:23 PM
RicK T's Avatar
RicK T
How old is the battery? Electrical misbehavior is frequently caused by a bad battery, even one that "seems" to be good. If you don't want to run out and buy a new one right away you should at least have the current one properly load tested. A member in General just posted tonight that his electrical gremlins, including 35 error codes, was ultimately traced to an "inferior" ($40) battery that had been installed by a family member when he was out of the country. The battery tested as good but was determined to not have sufficient power for the Vette. With installation of a new stock Delco battery everything is fine.
Old Oct 20, 2010 | 10:32 PM
PJohnsonATX
Not sure. Recently purchased the vehicle. If this persists, batter replacement will be my first step.
Old Oct 21, 2010 | 03:19 PM
cclive's Avatar
cclive
13 - 14 volts is the voltage produced by the alternator when the engine is running...not the battery voltage. Low battery voltage can certainly cause this behavior.
Old Oct 21, 2010 | 09:26 PM
bob guzzy's Avatar
bob guzzy
Dump the battery before it drives you nuts, no battery is worth the worry over if it's going to work.
Wally's worlds battery's work great and are way less than national brand names and last just as long, I have been using them for years without problems.
Old Oct 21, 2010 | 09:30 PM
VET4LES's Avatar
VET4LES
I agree with the others, sounds like the battery.
Old Oct 21, 2010 | 09:53 PM
cclive's Avatar
cclive
There are only a very few companies that actually manufacture batteries. Johnson Controls makes the ones at WalMart and they are less expensive and work fine.
Old Oct 21, 2010 | 09:56 PM
timd38's Avatar
timd38
They also make AutoZone, Advance, Interstate, AC-Delco and Motorcraft., to name a few.
They also own Optima.
To Strange electrical behavior...
