SS Brake Lines causing ABS/AHS/TC Problems
Old Oct 21, 2010 | 05:45 PM
COL Dave L's Avatar
COL Dave L
Default SS Brake Lines causing ABS/AHS/TC Problems
While aT VIR last weekend with my 2010 GS, I got DIC notices to service ABS, Traction Control and Active Handling systems and I could not turn on the Competitive Driving mode.
Dealer diagnosis, covered by a service bulletin, is that my Russell stainless steel brake lines are causing speed sensor faults. Fix is supposedly to install OEM brake lines. I had seven track days on the GS, with the SS lines, before experiencing this fault. I also had about 40 track days on my 2006 Z51, which had SS lines, and never had this problem.
Any and all help with this will be appreciated.
Old Oct 21, 2010 | 06:01 PM
timd38's Avatar
timd38
I guess I don't understand GM's logic.
Old Oct 21, 2010 | 08:51 PM
NYC6's Avatar
NYC6
I've read that once or twice here. Something about the steel affecting the signal somehow. Its obviously not a common thing. Maybe someone whos had the issue can help you.
Old Oct 21, 2010 | 09:14 PM
timd38's Avatar
timd38
I have metal lines and no issues.
Old Oct 23, 2010 | 09:58 AM
mfquinn's Avatar
mfquinn
I saw this a few days ago after I installed my new SS lines and I thought to myself "I don't have any problems". So today I start the car and I get "brake fluid low AH TC blah blah blah". Checked fluid level and it is fine. So, is there a fix? I don't want to take the lines off
HELP
Old Oct 23, 2010 | 11:23 AM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Stainless lines on all four corners here for over a year with absolutely no issues.
San
Old Oct 23, 2010 | 01:41 PM
TMyers's Avatar
TMyers
Brake line probably has nothing to do with it. Check out the article.
http://www.brakeandfrontend.com/Arti...eplacing_.aspx
Old Oct 23, 2010 | 02:14 PM
m R g S r's Avatar
m R g S r
that article states that the sensor failure was from corrosion...highly doubt that is the case on a 2010. the car was just built not that long ago....
Old Oct 23, 2010 | 02:30 PM
TMyers's Avatar
TMyers
It can also fail because of foreign debris. The OP has done 7 track days and this will put alot of stress on the system. Adding SS brake lines will not change the way the system operates.
Old Oct 23, 2010 | 04:19 PM
Bill Dearborn's Avatar
Bill Dearborn
If the brake line has continuity from where it attaches to the caliper to where it is clipped to the chassis you have a ground problem. You are not supposed to have a ground path through the brake line. The stock lines don't have continuity and most stainless lines don't either. If I remember correctly the Russell lines caused the same issues on C5s and were to be avoided. I had Earl's brake lines on my C5 and the connector that attached to the caliper had a ground break in it. On one side of the connector it was grounded to the caliper but on the side connected to the stainless hose there was no continuity to the caliper.
Bill
Old Oct 23, 2010 | 04:27 PM
Bill Dearborn
Actually that article is a little confused about the sensors. I have an 03 Tahoe that had the corrosion problem. It started when the traction control started activating in heavy traffic moving at slow speeds on dry roads. For others without traction control it showed up as ABS issues. The sensors in the trucks are like the ones in the early C4s. The bearing has a ring on the hub but the sensor plugs into the wheel bearing housing. Since the housing is cast iron on the trucks there is a fair amount of corrosion build up especially on trucks driven on wet/slushy/snowy salty roads. I have to take my truck in every couple of years to get the sensors cleaned.
Bill
Old Oct 23, 2010 | 07:31 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
I hate having to do **** twice when I am already there. Using an ounce of prevention when installing my SS lines, I wrapped them in black cloth automotive electrical tape and then covered it with black wire loom and taped the ends down.
Does it work, don't know, but I haven't had a problem either.
To SS Brake Lines causing ABS/AHS/TC Problems
