Mr gasket 160 issues
Old Oct 25, 2010 | 09:04 PM
aloandnina's Avatar
aloandnina
Default Mr gasket 160 issues
Installed a mr gasket (160) stat. Now it sounds like a pulley is squeaky.
Old Oct 26, 2010 | 03:34 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Sounds like you got coolant on the Belt or Pulleys.
Old Oct 26, 2010 | 05:30 PM
HANNY's Avatar
HANNY
dont use the belt dressing stuff it nasty. if you want take a crayon and while the engines running touch it agaainst the ribbed side. It will help it gain traction and tell you which belt is squeeling. (i think there are 2 on yours) then if it comes back later on just replace that belt. Also double check that the t-stat gasket/housing isnt slightly dripping either. I have seen them only drip a little at hot temps, clean it off under the housing good and see what you see
Old Oct 27, 2010 | 11:10 PM
aloandnina's Avatar
aloandnina
Took some royal purple lube and it took care of it.
Old Oct 28, 2010 | 08:48 AM
6Speeder's Avatar
6Speeder
You lubed the belt?
Good luck brotha!
Old Oct 30, 2010 | 01:32 AM
HANNY's Avatar
HANNY
Originally Posted by 6Speeder
You lubed the belt?
Good luck brotha!
:agree: if you put lube in it it wont squeal as much(because the belt is slipping and once it gets some grip back so will the squeal. Pretty easy to swap the 2 belts out cheap,,,,,,bet around 30-40 per belt o pick one up I would do it ASAP because. got any questions about and i can walk you thru it palu 7340610
plul your labor. and getting towork on . if you run intoi any snags feel free to pm me about my phone digits, good luck either, paul
To Mr gasket 160 issues
