F 55 Sims
Old Oct 27, 2010 | 10:11 PM
can_am_vett's Avatar
can_am_vett
Cruising
Default F 55 Sims
Ok, I seem to have a problem. I have a 2008 C6. Replaced the stock suspension with Pfadt coil overs. The 08 has the F55 option for ride control. I have purchased a set of sims from Casper Electronics. We have gone through three sets of sims to get the BCM to stop setting the suspension failure max speed 80 mph. Now I keep getting the "Service Suspension Max Speed 158 mph". The first two sets of sims showed that the resistor was burnt as the top of the sims showed excessive heat. The last set of sims has the wattage set correctly (maybe not) but is still setting the service suspension error message. Does anyone have a solution or a work around for this problem. Or has any one have this problem only with the 08 C6? I have searched the code to send to the BCM but as of today I have not found it. Nor have I found the correct resistance or wattage that is required to make the system think all is normal. Any help out there? BTW the PFADT Coil Overs are the best investment that I have made for the ride for this car. Unbelievable ride and tuning for the GTR.
Old Oct 28, 2010 | 05:57 AM
DarthStimpy's Avatar
DarthStimpy
See my post:
http://forums.corvetteforum.com/c6-t...d-dbs-fix.html
