Vibration under hard acceleration ?!
Old Oct 29, 2010 | 09:44 PM
c6_rob's Avatar
c6_rob
Default Vibration under hard acceleration ?!
Hello guys,
Recently ive picked up some nasty vibration under hard acceleration Its comes when im pinning 2nd or third gear from 3.5k to redline. I can really feel it in the shifter and the car almost feels like it has light wheel hop.
I inspected the tranny and motor mound with the car on stands but theres no real noticeable signs of damage. I know they could still be bad around the top where i cant really see but do you think this is it?
Again, it happens under hard acceleration only.
Old Oct 30, 2010 | 12:08 PM
c6_rob's Avatar
c6_rob
ttt
Old Oct 30, 2010 | 04:33 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Clutch slip?
Tom
Old Oct 30, 2010 | 04:59 PM
c6_rob's Avatar
c6_rob
I was thinking kinda thinking clutch slip. Does clutch slip typically smell? Any ideas on how to differentiate clutch slip from motor mounts etc?
Old Oct 31, 2010 | 05:54 PM
TCW's Avatar
TCW
Clutch slip sometimes doesn't smell under hard acceleration if it is just skipping on the pressure plate. (warped pressure plate)
To check for motor mounts, block all 4 wheels then have someone rev the engine and release the clutch SLOWLY. If you have a broken motor mount, the engine will rise up out of the cradle an unusual amount. You'll see right away that the engine is not secure to the frame.
Tom
Old Oct 31, 2010 | 07:52 PM
MarkRx's Avatar
MarkRx
could be shifter noise, oil sump, or even exhaust rattle. start there first, motor mounts are no fun.
Old Oct 31, 2010 | 10:46 PM
c6_rob's Avatar
c6_rob
Tom
Thanks, I will try this tomorrow
Old Oct 31, 2010 | 10:47 PM
c6_rob's Avatar
c6_rob
Im pretty sure its not shifter noise or exhaust. Tell me more about the oil sump though.
Old Oct 31, 2010 | 11:03 PM
TwinSpin's Avatar
TwinSpin
It could be clutch balance
Jay
Old Nov 1, 2010 | 10:41 AM
c6_rob's Avatar
c6_rob
Did a lil searching on clutch balance. Sounds possible. Ive got 42K on it and have had no clutch work. Do you think a clutch could just go out of balance like that?
Old Nov 1, 2010 | 04:36 PM
c6_rob's Avatar
c6_rob
I checked, not the motor mounts or tranny mpunts. Any other bushings back there? Torque tube, half shafts??
Old Nov 6, 2010 | 07:42 PM
c6_rob's Avatar
c6_rob
OK, not the clutch. I changed the shifter bushings, although it did need em it still does it. Its not the motor mounts. Any other bushings back there? Torque tube, half shafts??
Old Nov 9, 2010 | 10:19 AM
m R g S r's Avatar
m R g S r
it could be the CV's if its only under acceleration. the CV cups sometimes become pitted and vibrate only under acceleration
an easy way to see if thats the problem without spending any $ is to swap the left and right axles (im pretty sure theyre the same on a c6) because it moves the pitted area to the back side of the cup where the bearings inside the cv don't contact under acceleration.
Old Nov 9, 2010 | 12:33 PM
Robls6's Avatar
Robls6
Torque tube rubber couplings?
Old Nov 9, 2010 | 02:48 PM
c6_rob's Avatar
c6_rob
Thanks for the leads guys. Where are the rubber couplings located? Can I check them with the car on a lift? If its not the bushings im gonna swap the axles.
Ill just go down the list untill i find it!!!
Old Nov 7, 2016 | 06:02 PM
E39M5Speed's Avatar
E39M5Speed
any update on this issue?
To Vibration under hard acceleration ?!
