Headlights Low Beam Strange Problem
Old Nov 12, 2013 | 12:52 PM
cclive's Avatar
cclive
This type of fuse box is not confined to the Corvette...it is used in every GM car, so it can't be all that bad. This means that there are literally millions of these out there functioning every day. That one connection for the low beams is a weak point, easily fixed. Replacing the entire box seems like asking for trouble to me. There are a number of different ways of making that one connection more robust.
Replace the wire.
Solder it.
Add another wire so that both have to fail to disrupt the lights.
Old Dec 23, 2013 | 02:59 AM
Louiseven's Avatar
Louiseven
My friend has a 2005 with 89xxx on the clock. She is having the same issue. The fuse box gets really warm then the lowbeam headlights go out. I noticed when this happens if I apply a bit of pressure on the headlight relay the lights illuminate. Remove my hand and off they go. Checked for the broken wire and really didn't see much of crack. Replaced it anyway. Same problem!
Old Dec 23, 2013 | 10:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Inside the FUSE BOX, are solid copper wiring traces. The one for the head light can and will burn in half. You can disassemble the fuse box and repair /replace the trace yourself and save a ton of cash.
Give it a try.
Bill
Old Dec 23, 2013 | 05:01 PM
Louiseven's Avatar
Louiseven
Give it a try.
Bill
Thank you,
Yes I did take it apart and replaced the copper trace. To no avail, problem still persist. ?
Old Dec 23, 2013 | 09:03 PM
Ahmer's Avatar
Ahmer
I'm glad this thread popped up. Saw my post 2 years ago... Ah the lovely problems this car gives you, but just like an annoying girlfriend, she's just too pretty to get rid of...
Old Jul 14, 2014 | 05:14 PM
NETRIDER's Avatar
NETRIDER
Cruising
i just had this problem last night...it was about 90 degrees or more outside...roughly how much is this to have the dealership fix out of warranty?
btw its a 2007 c6
thank you in advanced!
Old Aug 7, 2014 | 04:29 PM
Josh C6's Avatar
Josh C6
I'm having this same problem. It's be in the 90s in ATL so I'm guessing it is the heat related issue. I will pop the fuse box and see what if the wire is done.
Old Aug 7, 2014 | 07:19 PM
vettematic's Avatar
vettematic
I believe they announced a recall for this last mid May 2014 in the news media. I have not received my official letter, it's been almost 3 months.
Old Dec 30, 2014 | 12:24 AM
kjlc's Avatar
kjlc
1st Gear
Default headlights
Originally Posted by djbrun
You can start with the normal headlight low beam function via the headlight switch.
The BCM has an internal pull up for it's digital inputs.
So with that pin high from the internal pull up it = OFF
Pulled low from a switch or relay to ground= ON
So if the headlight switch is turned on, PIn 15 on the BCM should be pulled low via the headlight switch to ground 201. If the parking lamps turn on then that ground is good, if neither the parking lamps and the headlights do not turn on, then you could take a jumper wire form pin K on the headlight switch to ground. If they turn on then you need to trace that ground connection. If they do not turn on and pin 15 on the BCM is low, then check pin C2-3 on the BCM for a low signal. This is what toggles the ground for the low beam relay. If you have any questions on this just let me know.
DJ
I have exact same problem with low beam head lights. Parking lights work indicating grnd 201 is good. Have grounded output of BCM to relay 47 and head lights come on. indicating relay good. At BCM pin 15 what meter do I use to determine hi or low cond. and what value on meter am I looking for? Any help would be greatly appreciated.
Old Dec 30, 2014 | 09:32 AM
djbrun's Avatar
djbrun
Did you try the link that Clive posted in #19?
There is a heat expansion issue that is common at the fuse box in the engine bay.
