Which o ring melling 296
Old Nov 10, 2010 | 02:05 PM
ITS STOCK's Avatar
ITS STOCK
Default Which o ring melling 296
I bought a melling 296 to put on my ls2 while I do the cam swap I'm changing the oil pump. It came with two springs and 2 o rings. I'm going to use the stock pressure relief spring that came with it but I'm not sure which o ring to use the green or black one. If anyone help me out I would greatly appreciate it.
Old Nov 14, 2010 | 11:34 PM
SgtRod's Avatar
SgtRod
Did you get the high volume or the standard volume oil pump?
BUMP
Old Nov 15, 2010 | 10:48 AM
ITS STOCK's Avatar
ITS STOCK
It is the high volumn pump. I used the black o ring and it has great oil pressure 42psi at idle when warm and 80+ when wot.
To Which o ring melling 296
