help w wheel offsets!
Old Nov 11, 2010 | 11:13 PM
jburt's Avatar
jburt
Default help w wheel offsets!
Does anyone know the wheel offsets so you can run Z06 wheel and tire sizes on a standard C6 without a wide body kit? Can this even be done? Would the offsets change with a 19/20 wheel set up, if so what?
Old Nov 12, 2010 | 12:42 AM
TeamYellow's Avatar
TeamYellow
You can run 18 x 9.5 with +56 or +57 mm offset in front and either 19 x 10 with +66 mm in the rear or even go to 11" with +79 mm in the rear. These are reproduction wheels which you can get from several Forum vendors. The OEM Z06 offsets will cause the wheels to stick out past the fender on a standard C6.
