upgraded haltshafts?
Old Nov 14, 2010 | 08:27 PM
STROKD's Avatar
STROKD
Default upgraded haltshafts?
So what's the best alternative to replacing the stock half shafts to handle a harder launch? Car in question is a stock coupe 2008 c6
Old Nov 14, 2010 | 09:48 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
If the car is stock (no mods) why replace the half shafts? How hard a launch ?
The A6 should be fine even with a higher than stock stall speed converter. If you mod a M6 you may need to upgrade the suspension/tires to deal with wheel hop. The rear would most likely go before the half shaft.
Old Nov 14, 2010 | 10:09 PM
dsp300c's Avatar
dsp300c
Strkd is a cam, bolt on, nitrous ls3 m6 on drag radials. He meant stock as in he has stock halfshafts. I told him best bang for buck is c5z halfshafts unless he wants to spend like $1200 on a pair from ecs. Not sure what other options there are.
Old Nov 14, 2010 | 10:17 PM
Boomer111's Avatar
Boomer111
DTE has some options on build.
Old Nov 15, 2010 | 12:22 AM
lockman's Avatar
lockman
man for $1200 you can replace your stock ones 4 times there are harden shafts out there for $300.
Old Nov 15, 2010 | 06:06 AM
timd38's Avatar
timd38
LG has them and they a 5 min from Allen TX.
Old Nov 15, 2010 | 07:35 AM
Robls6's Avatar
Robls6
The axles in the diff would most likely break before a CV joint halfshaft will.... but as stated already, the C5Z halfshafts are supposed to be stronger and will slip right in there.
Old Nov 15, 2010 | 11:46 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
C6 Corvette Axle Upgrades
We offer 300M Alloy Axle shafts for extreme use, must use upgraded axle gear on right side.
Feel free to give me a call with any questions.
Tom 1-800-962-9632 ext 240.
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Nov 15, 2010 | 01:36 PM
NitrousMan's Avatar
NitrousMan
The C5Z axles should be good to get you into the 8's without any problems, much beefier than what was in my 05.
Old Nov 15, 2010 | 01:43 PM
STROKD's Avatar
STROKD
I have a beefed up diff with 300M shafts and gears.. When I launched at 4k it broke the carrier hub and possibly jacked the left half shaft too.. Just wanted to put somethin better back in it if I have to replace it anyway..
To upgraded haltshafts?
