What about this to make the 05 diff stronger?
Old Nov 14, 2010 | 10:42 PM
360jeepboy's Avatar
360jeepboy
Default What about this to make the 05 diff stronger?
http://www.corvettegarage.com/produc...-corvette.html
So the first thing I want to do to my new 05 C6 is change the rear axle ratio from 3.42:1 to 3.90:1. But the fact that the rear diff is weak, or weaker then the 06 and up, makes me worried to drop money in it for fear of it breaking. I was on corvette garage and found this differential strut. (link above). I don't mind droping 400 bucks on the brace if it will solve the problem, but will it solve the problem?
I also want to send the diff to DTE to get the ratio changed, are they a good company, or should I go with a different place.
Thank you for all your help!
Old Nov 15, 2010 | 12:00 AM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
That brace does nothing to reinforce the 05 differential. The 05 rear differential splits down the middle 90% of the time because of the weak center case. Your best bet is to just upgrade to an 06+ style differential and forget its back there.
As for DTE they are no longer a supporting vendor on corvette forum. Why not let us here at RPM Transmissions help you out?
Old Nov 15, 2010 | 12:28 AM
LS1LT1's Avatar
LS1LT1
RPM knows their stuff.
Old Nov 15, 2010 | 12:52 AM
cranky's Avatar
cranky
RPM definely knows how to upgrade. just do it and be done with it.
Old Nov 15, 2010 | 08:08 AM
dennis50nj's Avatar
dennis50nj
Cartek just did an 09 conversion with the rpm adapter in my 05 a4
Old Nov 15, 2010 | 09:55 AM
360jeepboy's Avatar
360jeepboy
Do you have a web site for rpm?
Old Nov 15, 2010 | 10:19 AM
360jeepboy's Avatar
360jeepboy
Ok I found the site.
So I see you can upgrade to an 06 diff for 600 dollars. So how much would it cost to do the upgrade to the 06 diff and have a 3.90 gear put in it?
Also, it says upgrade to an 06 diff for only 600 dollars. Does that 600 come with everything you need to put the 06 in the 05, or is there something else that I would need to buy. I read somewhere else about the transmission bellhousing needing changed.
Old Nov 15, 2010 | 01:25 PM
Robls6's Avatar
Robls6
I wouldn't spend any money on an 05 diff. You cannot beat RPM for service either. Let them have at it and you'll be happy. I've had built Level V tranmissions in my last 2 vettes with no problems at all.
Old Nov 15, 2010 | 04:47 PM
pomppe's Avatar
pomppe
Ok, I have 2005 C6 Z51, with 500 rwhp, and I want to upgrade my differential to 06+ differential. Do I need just the new differential, or is the more parts I need? How much total? Do You ship to Finland? Thanks! Jari.
Old Nov 15, 2010 | 05:43 PM
dennis50nj's Avatar
dennis50nj
YOU NEED THE ADAPTER THATS ABOUT 600 THEN YOU NEED AN 06 OR UP SECOND GENERATION DIF
Old Nov 15, 2010 | 05:53 PM
saplumr's Avatar
saplumr
If you can come up with a few more $$ get the Z06 diff. RPM did mine and I was blown away by their knowledge, efficiency and what I can classify no other way but professionalism. Footnote...I'm not easily impressed.
Old Nov 15, 2010 | 07:45 PM
360jeepboy's Avatar
360jeepboy
So about how much will a diff swap, and regear cost? I'm not looking to spend more then 2500-3000 dollars.
Old Nov 15, 2010 | 08:14 PM
saplumr's Avatar
saplumr
Cost diffs by what you can afford. Give Rodney a call.
http://ad.doubleclick.net/click%3Bh%...smissions.com/
Old Nov 15, 2010 | 08:34 PM
dennis50nj's Avatar
dennis50nj
and if your an 05 a4 you have to use a manaual dif now with an adapter. if you go zo6 you have to change the main shaft in your a4 and still have the adapter
Old Nov 15, 2010 | 08:39 PM
saplumr's Avatar
saplumr
Uh huh....but some of us know if the diff goes it's probably going to take the mainshaft with it...don't we.
Old Nov 15, 2010 | 09:07 PM
dennis50nj's Avatar
dennis50nj
Old Nov 15, 2010 | 09:21 PM
360jeepboy's Avatar
360jeepboy
Well it is a manual. So no adapter?
To What about this to make the 05 diff stronger?
Old Nov 15, 2010 | 09:40 PM
dennis50nj's Avatar
dennis50nj
i think you need an adapter to go with the second generation case on any 05 stick or auto
Old Nov 15, 2010 | 10:02 PM
360jeepboy's Avatar
360jeepboy
Is that included in the 600 dollar cost that RPM charges or is that extra?
Old Nov 16, 2010 | 06:40 AM
PRE-Z06's Avatar
PRE-Z06
just to be clear there aren't aftermarket gears available for the larger z06 diff, if he wants 3.90s as stated
