It's been 18 months
Old Nov 20, 2010 | 09:51 AM
cobraduke's Avatar
cobraduke
Default It's been 18 months
When I first reported the fact that my directional signals would sometime speed up I was told there is a bulb ready to blow. It's been 18 months of living with this problem and all lights still work, and the directional signal keeps doing the annoying speeding up. HELP!!!
Old Nov 20, 2010 | 11:35 AM
Bill Suttie's Avatar
Bill Suttie
I assume that you have replaced your flasher and all of your directional bulbs?????
Old Nov 20, 2010 | 01:25 PM
JoesC5's Avatar
JoesC5
C6 does not have a flasher on the signal lamps, only for the Emerg 4-way flasher. The flash rate is controlled by the computer. As part of warning when a bulb is burned out, the computer will go into hyper flash mode to warn the driver he has a bulb out. Might have a high resistance connection at the bulb making the computer think the bulb is gone
Old Nov 20, 2010 | 04:53 PM
Bill Suttie
I checked my service manual, there was nothing concerning your problem. I hope that someone with electrical experience will chime in. When you get to be my age, you don't use turn signals. Good luck.
Old Nov 21, 2010 | 05:46 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
The turn signal flasher is integrated into the Hazard Warning Switch, you might try replacing that and see if it resolves your problem.
Old Nov 21, 2010 | 11:21 AM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
Have any of the bulbs been replaced with LEDs?
Old Nov 22, 2010 | 05:09 PM
cobraduke's Avatar
cobraduke
Default Thanks
Thanks for the feedback. I'll try the flasher that is integrated in the hazard flasher.
To It's been 18 months
