Air Conditioning & Heating
Old Nov 21, 2010 | 07:38 PM
wingbone's Avatar
wingbone
Default Air Conditioning & Heating
On my C6 i turn the Temperature on the Drivers side to 60 and cool air Blows, When I turn the air on the Passenger side to 60 and the heat blows hot air. Has anyone had this problem?
Old Nov 21, 2010 | 07:56 PM
RicK T's Avatar
RicK T
Most likely a failed actuator. They were a big problem on the C5 and seem to now be turning up the same on older C6's. Pretty expensive to fix because the dash has to be removed, looking in the area of $1400. There are 4 actuators so if you decide to have the one broken one fixed be sure to tell the tech to replace all 4 while he's in there so you don't have to do the labor again next year. Sorry.
Just FYI this is an example:
http://forums.corvetteforum.com/c6-t...-material.html
Old Nov 22, 2010 | 12:04 PM
TY'Z Vette's Avatar
TY'Z Vette
I am having the same problem, I disconnected the battery for 30 min and now I they are blowing equaly...But my AC will not blow cold..
I am taking into the dealer... I will post the findings but my guess is the Actuators are bad as stated above...
Mine is also on 05
Mine was in reverse...Driver side was hot passanger side cold.....
To Air Conditioning & Heating
