ls3 cam install
Old Dec 3, 2010 | 01:39 AM
fman's Avatar
fman
Cruising
Default ls3 cam install
Let me start by saying that I am new to this forum I know that I am not building a corvette but I have found best source of info for me here.
I am building a 1970 Camaro with a fuel injected LS3 and a T56 I want good power and excellent manners I have decided to use Spinmonsters cam and was wondering what other parts I should install with cam I want to upgrade the timing chain
What size primaries do you suggest on the headers
What do I need to change as for type of cam core and chain gear change
What spring and retainers are required and should the stock rockers be changed
Are any mods required or changes needed to be done to oil pump
What push rod will I need
I have herd that the LS3 valves have been an area to look out for on higher spring pressurizers or is it nothing to be concerned about with this set up
After all is completed I plan on having a tune done
The motor is a LS3 from a 2011 Camaro with 4 miles
Old Dec 3, 2010 | 03:01 AM
SpinMonster's Avatar
SpinMonster
1 3/4 for good low end with the heavy car. Longer primaries if you can find them would serve you well.
Cam will be a 3 bolt and use a IWIS chain....katech
Partriot gold extreme duals comes with retainers and seats
stock rockers are fine
No.
7.425 but know different brands dont measure exactly what is published. A comp cams 7.4 is 7.416
I have herd that the LS3 valves have been an area to look out for on higher spring pressurizers or is it nothing to be concerned about with this set up. I have no data to support that other than the number of cammed LS3's running 400lbs. I run solid valves...no likey hollow stems. I can rev to 7000 with the heavier valve so with these springs they dont float.
when you have it tuned, the tuner should be aware that the LS3 makes best power lower than 13:1 A/f ratio. Most see 12.3 to 12.7 and this is likely in part due to 10% ethanol fuel.
Old Dec 3, 2010 | 11:07 PM
fman's Avatar
fman
Cruising
Thanks or the info you have been a great help.
should I try and find a push rod .009 longer or the 7.4 good without any rocker to valve concerns
Old Dec 3, 2010 | 11:46 PM
tomiboy's Avatar
tomiboy
Spin, as you know, I want to do this cam in the spring. I too am interested in who carries hardened pushrods in this size.
Old Dec 31, 2010 | 09:56 PM
fman's Avatar
fman
Cruising
I have a set of gold springs and retainers can I use them or should I change to the gold extreme
To ls3 cam install
