High Oil Pressure Reading
Old Dec 21, 2010 | 09:15 PM
bocallaghan's Avatar
bocallaghan
Default High Oil Pressure Reading
So I noticed on my car tonight that my oil pressure gauge was pegged down below the 80 on my instrument panel. I scrolled through the diagnostics and noticed I had a reading of 130 psi that fluxuated down to about 117 psi. No error message came up on the panel. What should I start with in diagnosing what is causing this abnormal reading? Also, what is a normal reading and is it safe to drive? Thanks for your responses. Merry Christmas!
Old Dec 21, 2010 | 10:14 PM
B y r o n's Avatar
B y r o n
I'd probably start with a trip to the dealer to verify the numbers assuming everything is stock.
Old Dec 22, 2010 | 12:37 AM
m R g S r's Avatar
m R g S r
anyone know what kind of sensor (3 bar, 4 bar etc) is used? thats a lot of pressure, does the sensor even read that high?
sounds like a bad sensor to me.
Old Dec 22, 2010 | 08:49 AM
LEAVINU's Avatar
LEAVINU
Bad sensor. I've been through 2 or 3 of them myself because of water hitting the top of the sensor and shorting them out. I've since corrected the water drainage issue.
The sensor is designed to "peg" when it goes bad. Easy fix thankfully. I "heard" the brass aftermarket sensor is suppose to be better. I picked on up from Adv Auto for pretty cheap. Either way you can still get a stock one pretty cheap from the dealership.
Unless you can fit a deep socket back there you'll need to pull the intake to swap it out. I actually made a hole under the plastic trim at the cowl to access mine from above. R&R took no time.
Old Dec 23, 2010 | 05:34 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
The first thing I would do is check the oil level.
Old Dec 23, 2010 | 12:34 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Old Dec 24, 2010 | 06:15 PM
Ahmer's Avatar
Ahmer
Ok i too have this problem now. I am debating dealership versus self.
Old Dec 24, 2010 | 06:51 PM
tjwong's Avatar
tjwong
You have a bad sensor, all it takes is to remove the intake manfold to get access to the sensor that is directly behind the intake. Just replace it and you will be fine.
Old Dec 24, 2010 | 07:26 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
or you can do this: http://forums.corvetteforum.com/1558850078-post7.html
Elmer
Old Dec 24, 2010 | 08:26 PM
Ahmer's Avatar
Ahmer
Hmm. I think I may have to warranty this one out. Also is it worth it to do the SERVICE II??? Where they replace spark plugs and do a fuel system overhaul and some other things???
Old Dec 25, 2010 | 02:18 AM
d.medic's Avatar
d.medic
St. Jude Donor '10
Don't you have a new motor under warranty? Let them do it
Old Dec 25, 2010 | 09:41 AM
Ahmer's Avatar
Ahmer
True. Yes I will do that. THanks guys. Its just the rental PITA I hate dealing with
To High Oil Pressure Reading
