###help###
Old Dec 27, 2010 | 01:26 PM
stalker26's Avatar
stalker26
Default ###help###
I was driving my 06 6spd down the road and it turned off as i was accelerating. It showed service engine and traction system right away and than wouldnt start back up. Now it is just making a sound like the starter is just running and wont turn off until you turn the car off. I have 4 codes
p0341
p0106
p0101
p0068
any help would be grately appreciated.
Old Dec 27, 2010 | 01:32 PM
5knives's Avatar
5knives
p0341
p0106
p0101
p0068
P0068 -MAP/MAF Throttle Position Correlation
P0101 -Mass or Volume Air Flow Circuit Range/Performance Problem
P0106 -Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0341 -Camshaft Position Sensor Circuit Range/Performance
I'm not sure what all of this means but hopefully this will help someone else figure it out. Also check this site for help.
http://www.obd-codes.com/trouble_codes/
Best of luck. Hopefully it's just a minor electrical glitch.
Old Dec 27, 2010 | 02:22 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would think that camshaft position sensor is the issue. If the PCM doesn't know the position of the camshaft, nothing is going to work. Timing chain break?
Old Dec 27, 2010 | 02:31 PM
stalker26's Avatar
stalker26
how would I know if a timing chain broke?
Old Dec 27, 2010 | 03:47 PM
EVRose's Avatar
EVRose
That's exactly what I thought when I saw that 0341 code.
I would have it towed to a dealer. Don't try to start it or it could screw up a lot of things if it's a broken timing chain.
Old Dec 27, 2010 | 04:09 PM
timd38's Avatar
timd38
06 has three bolts on cam, so I doubt that it broke the pin.
Old Dec 27, 2010 | 04:11 PM
5knives's Avatar
5knives
stalker26, do you have any mods on the car?
Old Dec 27, 2010 | 04:30 PM
stalker26's Avatar
stalker26
I wish.. Im bone stock
Old Dec 27, 2010 | 05:06 PM
cranky's Avatar
cranky
starter spins freely= no compression. valves bent from timing chain breaking. valves stopped moving, pistons smacked them............... only way to know for sure is to pull a valve cover and crank the engine over. if the chain has broken, the rocker arms will not be moving......
Old Dec 27, 2010 | 05:30 PM
stalker26's Avatar
stalker26
so in other words... im screwed?
Old Dec 27, 2010 | 05:34 PM
Boomer111's Avatar
Boomer111
Only if you do not have any extra money!
Old Dec 27, 2010 | 05:38 PM
timd38's Avatar
timd38
The chain could have jumped a tooth, but the results are the same.
Old Dec 27, 2010 | 05:39 PM
stalker26's Avatar
stalker26
so yep... im screwed....
Old Dec 27, 2010 | 06:32 PM
5knives's Avatar
5knives
Well before you start freaking out, find out exactly what happened.
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
You might get more help and better suggestions if you posted your location.
Old Dec 27, 2010 | 06:39 PM
stalker26's Avatar
stalker26
Im in Houston TX
Old Dec 27, 2010 | 06:55 PM
BearZ06's Avatar
BearZ06
That's a plus for you because there are several choices for shops to repair your car. Some guys from your area should respond with advice on that. It may not be as bad as you think, just have it checked out at a trustworthy and knowledgeable shop. You could also try posting in the C6 General Section for more responses.
To ###help###
Old Dec 27, 2010 | 06:59 PM
5knives's Avatar
5knives
Im in Houston TX
Other than maybe the Northeast USA, no area of the country has more qualified LS tuners than TX.
Old Dec 27, 2010 | 07:00 PM
RicK T's Avatar
RicK T
There are a lot of Forum members in Houston area if you're wanting some free help. As mentioned, ask in the General Forum and also the Southwest Regional Forum. Best of luck and please let us know what happens.
http://forums.corvetteforum.com/southwest-44/
Old Dec 28, 2010 | 02:38 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Did you notice anything weird before this happen or ever? Can you take off the fuel rail covers and check all your connectors for me. I wouldn't worry until you are sure its something bad
