M6 to A4 conversion
Old Dec 29, 2010 | 05:23 AM
SpinMonster's Avatar
SpinMonster
Default M6 to A4 conversion
Does anyone know how to do this?
I know it doesnt cost the 17k RPM wants for a kit.
Old Dec 29, 2010 | 05:25 AM
SpinMonster
I have a 2005 and know thw transmission control unit is in the trans so is it just a plug and play ordeal?
Old Dec 29, 2010 | 06:27 AM
breecher_7's Avatar
breecher_7
im pretty sure you can just swap out the mechnicals and everything will work just fine. Ive never personally done this swap but I know people that have and I dont believe they had any issues with it.
Old Dec 29, 2010 | 10:15 AM
SpinMonster
I guess the PCM is told there is an auto then? When you tune an M6 it doesnt have the A4 tables for tuning. Is it recognized or get flashed?
Can you put me in contact with someone who did the swap?
Old Dec 29, 2010 | 10:35 AM
edcmat-l1's Avatar
edcmat-l1
Spin, I've done a few Fbodies. They're as simple as an OS swap (after the mechanical stuff is done). Not sure how a Ybody will like the (OS) swap though. I would think worst case, flash with a Tech2 and go from there. Might have some issues with the BCM RPOs.
To answer your question though, no it does not do an automatic recognition.
Old Dec 29, 2010 | 10:48 AM
SpinMonster
Thanks.
With that info, Im baffled as to why RPM wants 17,000 bucks for the kit. I couldnt see it coming to more than 5k for parts plus their trans build on a 4L60 (2K for that?). Labor appears to be 10-12 hours to install everything.
Old Dec 29, 2010 | 10:54 AM
carlrx7's Avatar
carlrx7
i say just run a mechanical valve body.
Old Dec 29, 2010 | 11:06 AM
SpinMonster
Adjusting shift points would be fun. I dont know much about A4s so I prefer to be able to tune with a laptop.
It would solve a few things for sure.
If it wasnt so street unfriendly, I'd be sporting the ECS powerglide right now. Chris said its not for me but I want to track the car with big power. At 6800feet elevation and the trans doing the work, I would likely get my first successful 9 sec pass with me driving my own car. I cant shift for my life.
Old Dec 29, 2010 | 11:16 AM
edcmat-l1's Avatar
edcmat-l1
Still won't deal with the start P/N issue, or the idle/load P/N/gear issue. Personally, I really like the tunability of the 60s and 80s and A6s. I'd much rather have a computer controlled trans than a 400 or PG.
Old Dec 29, 2010 | 12:06 PM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
Spin,
The $17k price tag isn't the transmission swap alone. That price includes everything in the entire drivetrain. From the engine back. That includes an SFI flexplate, SFI bellhousing, automatic torque tube, DSS prop shaft, Poly couplers, SFI converter drive flange, PI Vig converter with your choice of stall speed, Built Level 7 4L65e transmission, Stage 3 differential with your choice of gear ratio and 300m chromoly axle shafts, an TCI T-com transmission controller, automatic transmission pedal assymbly, automatic shifter, shifter cable, all cruise control and TCC lockup provisions are retained just like a factory installed automatic car. The price includes installation and transmission tuning.
The $17k is our top of the line A4 conversion without upgrading to the 4L80e or TH400. We would be more than happy to figure you a quote that better suits your needs if you choose not to go with all the upgrades we have available.
Just give me a ring if you have any other questions. I'd be happy to talk to you.
Thanks,
Jeremy
Old Dec 29, 2010 | 02:46 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
i foresee automaticmonster diy thread coming soon
Old Dec 29, 2010 | 08:09 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
For $17K I'd rather buy a stock auto car and transfer the mods then sell the M6 car.
Old Dec 29, 2010 | 08:13 PM
timd38's Avatar
timd38
In fairness, the 17K includes a bunch of stuff including the trans.
Old Dec 29, 2010 | 10:12 PM
CYA-Vett's Avatar
CYA-Vett
Its really more geared toward Z06 drag racers where there is no auto available. I had the swap in my C5 Z06, I loved it, the whole conversion is seamless. ECS did the work but it wan an RPM tranny/parts.
Old Dec 31, 2010 | 11:38 PM
todd@rpmtransmissions's Avatar
0todd@rpmtransmissions
Former Vendor
Just an FYI, the 2005 still uses the 4L60E with an external control unit. The 6L80E uses the internal TCM.
Old Jan 1, 2011 | 01:23 AM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
With the A4 the TCM is mounted on the same bracket as the ECM in the passenger side fender.
I am doing just the opposite, I went from an A4 to the MN6 (complete A4 setup for sale). I have my car running but I am waiting until the holidays are over to get access to a Tech II. The BCM needs to see the TCM on GMLAN network, you will have to program the BCM with a Tech II. This also fixes a few other things like the DIC telling you to put your car in PARK instead of REVERSE and the cruise control working.
You can re-program the ECM easy enough with HP Tuners or EFI Live by doing a "write entire" with an A4 tune, do a "read entire" and tune from there. You can still apply your 2.5 or 3 bar OS if you use one since it is tied to your VIN.
If your car is an F55, the plug on the A4 harness is the same as the one on your engine harness. If it's not an F55 you will need both sides of the A4 plug.
Other than that it is just wiring.
Old Jan 1, 2011 | 03:16 PM
carlrx7's Avatar
carlrx7
I think you and spin should trade parts.
To M6 to A4 conversion
Old Jan 1, 2011 | 03:37 PM
'VETTE PHASE
I remember a year or so ago, two guys got together and did that very thing.
I wish I had known someone that was doing the swap. I bought a wrecked '06 Z51 MN6, used what I needed and I am parting out the rest.
Old Jan 1, 2011 | 06:48 PM
SpinMonster
Selling a 2005 for 25K and buying the A4 car for 25K makes way more sense than buying all that. I'll just wait on the C7 and get the auto then. Hopefully the C7 will have the 6l90 and then the build cost for the trans will be at 1000 or so to strengthen it along with a higher stall. Paying 75% or the value of the car for an upgrade makes no sense.
If anyone with an A4 wants to trade parts with me doing all the work, please PM me. That I will go for. My trans is fully built and my diff has 2 hardened shafts with 4.10's. Its a C5 model and has been proven to run 9's on Cartek's R&D 2005 car.
Old Jan 1, 2011 | 06:51 PM
SpinMonster
Will you sell me instructions on an A4 how-to swap? What do you guys do for a diff? Id like to continue to use a C5 as they handle insane power. Built 2005 C6 diffs are a time bomb.
