Radiator compatibility
Old Jan 1, 2011 | 02:14 AM
ChRpin VETT's Avatar
ChRpin VETT
Default Radiator compatibility
Hello there about to buy a used oem radiator, it's from an 06 corvette with annautomatic transmission.
My question is whether it will fit my 05 with a manual transmission?
Im thinking the transmission cooling lines wouldn't be the same.
Old Jan 1, 2011 | 02:29 AM
tjwong's Avatar
tjwong
The radiator will fit fine, and if you have the Z51 package with the transmisson cooler the lines will just plug into the 06 radiator as long as it has the trans cooler.
Old Jan 1, 2011 | 07:51 PM
Motorhead-47's Avatar
Motorhead-47
If the car is a 2005 Z51 MN6 it was equipped with an engine oil cooler in the radiator along with the transmission oil cooler.
To Radiator compatibility
