Cam degree kit
Old Jan 3, 2011 | 10:30 PM
Ginny C6's Avatar
Ginny C6
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default Cam degree kit
It looks like due to my budget, or lack thereof, I will have to install my cam myself. It's been recommended I install it +2. Looking online, the cam degree kits are approx. $180 or so. Does anyone have a used one for sale or rent? I don't think I will ever need one again, so I really don't want to buy a new one. Kevin
Old Jan 3, 2011 | 11:12 PM
lockman's Avatar
lockman
I don't have one but did you check ebay?
Old Jan 5, 2011 | 12:23 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
Yes, but they are all new. If I have to buy one, I"ll have a used for sale in a few weeks
Old Jan 5, 2011 | 01:25 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Just go ahead and install it dot to dot (lined up on the cam and crank gear) and you'll be fine. I've installed several +2 cams in LS motors without using a degreeing kit and have never had a problem. In fact, the one time I did actually use a degreeing kit (when I was rebuilding my Grand National motor) after buying the kit and figuring it out how to use it properly, it ended up lining up dot to dot anyway.
Old Jan 5, 2011 | 01:43 PM
Ragtop 99's Avatar
Ragtop 99
Is the cam ground with the +2 or are you trying to advance a cam you own by an additional 2*? If it is the latter, I'd get an adjustable timing chain set and do that way.
Old Jan 5, 2011 | 08:44 PM
Ginny C6's Avatar
Ginny C6
St. Jude Donor '11
I found a friend with a cam degree kit. I'm unfamiliar with the process, but he is going to show me how it works. Spin recommended I install the cam +2, so that's why I'm doing that. I installed a cam in my Camaro recently, but didn't degree it. I'm getting a Katech C5R timing chain, is that adjustable?
Old Jan 5, 2011 | 10:06 PM
Ragtop 99's Avatar
Ragtop 99
no.
To Cam degree kit
