catback vs. catback w/headers
Old Jan 5, 2011 | 08:44 AM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default catback vs. catback w/headers
i love the sound of my car (bassani cat back system), but would like it to sound a little bit more aggressive w/o losing that sweet exhaust note.....i bought some 1 7/8 kooks headers,lg hi-flow cats,fast 102lsxr intake (ported).....mow much is this going to change the exhaust note?
Old Jan 5, 2011 | 08:57 AM
FloydSummerOf68's Avatar
FloydSummerOf68
Headers make a BIG difference in how the car sounds.
Old Jan 5, 2011 | 09:18 AM
C U IN REARVEIW
will i lose that low grumble sound?
Old Jan 5, 2011 | 10:11 AM
FloydSummerOf68
Your car currently has an H-pipe on it which DOES provide a bit deeper tone than an X-pipe, but overall the general tone of your car will be similar, as the mufflers have greatest effect on that, just much louder and you will have more drone around 1500-1700 rpms.
If you install the longtubes and the ported FAST at the same time you'll be driving an entirely new animal. You'll love it.
Old Jan 5, 2011 | 10:56 AM
C U IN REARVEIW
i have the bassani installed as of now,has an x=pipe built in to it,so the kooks,cats,intake will all be going on at the same time because it will require a tune....how mus
ch differance did your fast make?
Old Jan 5, 2011 | 11:01 AM
ITS STOCK's Avatar
ITS STOCK
If you have an LS2. You will probally see 20-30whp with a ported FAST on a bolt on car.
Old Jan 5, 2011 | 11:03 AM
C U IN REARVEIW
what do you think i will gain doing fast,kooks lt,lg cats,tune?
Old Jan 5, 2011 | 11:26 AM
FloydSummerOf68
You'll probably gain in the realm of 50-60rwhp at peak and pick up TONS of power/torque under the curve.
Old Jan 5, 2011 | 11:28 AM
FloydSummerOf68
Ah I see, I didn't know you had the bassani x-pipe installed. I was assuming just the rear-section and kept the stock h-pipe.
In that case, the "tone" of the exhaust won't change that much, but it will be greatly amplified and will only be slightly higher pitch due to the construction of the longtubes versus the very heavy stock manifolds.
Old Jan 5, 2011 | 11:33 AM
C U IN REARVEIW
thanks for the info...
Old Jan 6, 2011 | 11:00 AM
Schoolteacher's Avatar
Schoolteacher
When I put my headers and catted 3" x pipe after already having magnaflow mufflers it made the tone more ringy sounding. Quite abit more aggressive. I love the way it sounds.
Old Jan 6, 2011 | 12:05 PM
NYC6's Avatar
NYC6
Not gonna see that much with a FAST, ported or not.
Old Jan 6, 2011 | 12:06 PM
FloydSummerOf68
20-30rwhp is actually the norm for a ported FAST on an LS2
Old Jan 6, 2011 | 12:11 PM
NYC6's Avatar
NYC6
Seems like alot. I would love to see a dyno of only a FAST install and see what the actual gains are.
Old Jan 6, 2011 | 01:07 PM
FloydSummerOf68
People get ~15 from just a ported stocker.
You don't believe that a ported FAST would at least add another 5rwhp?
Old Jan 6, 2011 | 01:18 PM
arcticZ51's Avatar
arcticZ51
Why is it the FAST is only referred to in terms of the LS2. Do they not make one for the LS3? TIA
Old Jan 6, 2011 | 01:29 PM
FloydSummerOf68
They make one, but the gains are far less in comparison to the LS2, which has the worst LS intake manifold since the 98-99 LS1 Fbodies.
The fact that the LS2 intake manifold is SO BAD is why the gains are so awesome.
To catback vs. catback w/headers
Old Jan 6, 2011 | 02:43 PM
NYC6's Avatar
NYC6
Most of what I hear is the FAST isnt much better than the ported stock unit. Lots of unsubstansiated claims as always with these things. I'm curious to see actual confirmed data showing close to 30 hp with a ported FAST. I havent seen any, have you? If its true(and maybe it is) I would consider one for my car.
Old Jan 6, 2011 | 02:57 PM
FloydSummerOf68
Yes, I have.
More than one thread has been on this forum showing gains over stock and over ported stock intakes.
You can search and find them.
Old Jan 6, 2011 | 03:04 PM
FloydSummerOf68
Here is a good thread showing the LS2 intake compared with various other intakes, including the FAST 90 (unported) showing 22hp and 22tq increase.
http://www.ls1gto.com/forums/showthread.php?t=289456
I should have my own dyno results tomorrow going from stock to ported FAST 90. I made 367 before. My mods since then have been the FAST 90 and a 3200 converter (which generally robs a little power on the dyno).
