tunnel plate
Old Jan 9, 2011 | 10:30 AM
Ragtop 99's Avatar
Ragtop 99
Originally Posted by YLOFEVR
I replaced my stock tunnel plate with a 1/4" Elite Mfg... After the install, there were actually (3) benefits which I noticed.
l. The roof creaking noise was gone--totally.
2. The car felt like it was on a more solid platform (best way to describe).
3. There was a definite temperature difference in the center console i.e. lower temperatures so that my sunglasses weren't hot and my chewing gum chicklets weren't hot...
I'm happy with the results and consider it a worthy addition.
Pretty much my results too although my console stills get warm enough to fail the Snickers test, it did slow down the process. I'd probably do the 3/8" plate and self insulate if I were doing it again.
Old Jan 12, 2011 | 07:34 PM
victorf's Avatar
victorf
Originally Posted by JLinNY
Placebo? So a person is going to think the car is stiffer because they want it to be? That is one of the stupidest things I have heard on here. Maybe YOU just couldn't feel a different
Original poster, I guess you are going to have to make up your own mind on this one.
MANY people on here have given this product a thumbs up. Including myself, and I am not one of those people who are going to endorse a product that doesn't work just because I bought it.
If I didn't notice a difference I would have taken it off and sold it. I don't work for the company, I have nothing to gain by keeping a product on my car that doesn't do what it is supposed to do.
John, that is disrespectful!
You call people names just because you disagree with them?
In you profile, you are a full time dad, well, this is where you and I are different and I can refrain myself to make comment here!
There is a definite chasm of knowledge base between us.
In Post #15 structural facts were briefly outlined.
Consider this:-
A. We all bought into a flimsy structured Corvette and we can reinforce by simply add a thicker tunnel plate to the existing weak anchorage points? This is not the same principle as anti sway bar.
B. We can reduce cabin heat by a combo thicker plate with insulation? All at the same time ignoring the fact that greater amount of radiant heat is due to the combo clutch and torque tube proximity which by the way, sandwiched between the tunnel plate and the already insulated tunnel.
Your statements "MANY people on here have given this product a thumbs up. Including myself, and I am not one of those people who are going to endorse a product that doesn't work just because I bought it.
If I didn't notice a difference I would have taken it off and sold it. I don't work for the company, I have nothing to gain by keeping a product on my car that doesn't do what it is supposed to do."
means nothing. It simply reinforced the notion that a lot of people falls for marketing hype and bought a whole lot of snake oils from snake oil salesman.
Old Jan 12, 2011 | 08:28 PM
keyplyr's Avatar
keyplyr
Very much worth it for my '05 vert.
When I bought the car (bone stock) one of the first things I noticed was the creak sound when I turned into a drive way at a slight angle. This happened top up or down. One side of the car adjusted to the driveway before the other side did.
After installing the 1/4" tunnel plate this stopped completely.
Old Jan 12, 2011 | 11:40 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I bought the Elite Engineering tunnel plate that is ceramic coated and has the thermal blanket.
In my case I just wanted to reduce the temp in the interior/center console area. And since I was replacing the exhaust system, it made sense to add this mod 'as long as I was at it'.
The heat reduction was substantial and I wasn't really expecting to feel any difference in the chassis, so it was very much worth the money IMO.
I don't think I would be able to quantify the performance benefits unless I had done before/after track testing.
But then my SOTP barometer has gotten numb with age.
Old Jan 13, 2011 | 01:45 PM
victorf's Avatar
victorf
Convertible are different from coupe structurally for sure. I am glad it works out for you.
One of my confirmations after install was my slanted driveway. One of these days I will replace it with stock, so I don't have to lug the extra weight around.
Old Jan 13, 2011 | 07:12 PM
timd38's Avatar
timd38
One of my confirmations after install was my slanted driveway. One of these days I will replace it with stock, so I don't to lug the extra weight around.
How much different is a convertible? The reason I ask is, once you take the roof off a coupe you have lost the "bridge" from the front to the back just like a convertible.
Not trying to be difficult, just trying to understand.
Thanks!
Old Jan 14, 2011 | 08:36 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Thanks!
The coupe has the "halo". I doubt the roof does very much stiffening.
Old Jan 14, 2011 | 06:21 PM
timd38's Avatar
timd38
So a coupe with a harness bar to stiffen the halo and a tunnel plate, should make the car really stiff.
Guess I am glad that I installed a "Shark Bar"!
Old Jan 14, 2011 | 09:17 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
what is a harness bar??
Old Jan 14, 2011 | 09:27 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
That's twice you've asked so I assume you're serious. A harness bar is a bar that facilitates the proper angle and mounting of aftermarket harness belts.
http://www.westcoastcorvette.com/p-1...and-sport.aspx
San
Old Jan 14, 2011 | 09:38 PM
C U IN REARVEIW
San
thanks
Old Jan 15, 2011 | 05:27 AM
timd38's Avatar
timd38
I like this one, because of the way it mounts, but you have the choice of several different kinds.
http://vetteworksonline.com/Corvette_C6bar.htm
Old Jan 18, 2011 | 10:37 AM
  #33
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
I replaced my stock tunnel plate with a 1/4" Elite Mfg. I also used LG Motorsports Heatmaster insulation panel. After the install, there were actually (3) benefits which I noticed.
3. There was a definite temperature difference in the center console i.e. lower temperatures so that my sunglasses weren't hot and my chewing gum chicklets weren't hot. (I love Snickers but I don't keep them in the car. I wolf them down before I get into the car LOL)
As for the heat transfer IMO, I think MOST (not all) of the heat emanates from the exhaust.
Yep, you should experience these same results.
Old Jan 18, 2011 | 10:40 AM
  #34
C U IN REARVEIW
mine is going on in two weeks (elite engineering)...along with headers,cats,and fast 102
Old Jan 24, 2011 | 10:02 AM
  #35
Elite Engineering
Supporting Vendor
St. jude Donor '14
Thanks for the purchase.
Old Jan 24, 2011 | 09:01 PM
  #36
gtorwalt's Avatar
gtorwalt
No diff for me on a street driven coupe. Waste of money.
Old Jan 24, 2011 | 11:20 PM
  #37
C U IN REARVEIW
how can there be such completely differant opinions??
To tunnel plate
Old Jan 25, 2011 | 07:48 AM
  #38
timd38's Avatar
timd38
Maybe he lives in Alaska?
Old Jan 25, 2011 | 08:32 AM
  #39
davekp78's Avatar
davekp78
Placeabo effect.
Old Jan 26, 2011 | 09:47 AM
  #40
Tarheels1's Avatar
Tarheels1
Placeabo effect...Some are saying, but I could tell a difference right away on my Convertible. Yes it is costly, but so are our Vettes. Yes some could make their own, but who has the time and energy these days? Elite Engineering has it all figured out. IT DOES STIFFEN THE CHASSIS TO SOME DEGREE. Could the chassis on a convertible be stiffened more? Yes, but I think one would have to bark up another tree somewhere else.
