tunnel plate
Old Jan 7, 2011 | 04:13 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Default tunnel plate
want opinions on the benefits of thicker/insulated tunnel plates....anyone have thoughts/first hand expirience with them? did it make a differance? worth the $ ?
Old Jan 7, 2011 | 04:52 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
My tuner said for the C6 there wasn't really a need. I was doing headers and opted to leave the stock plate there. I would think the harness bar stiffening up the mid-chassis would make more of a difference.
San
Old Jan 7, 2011 | 05:03 PM
C U IN REARVEIW
San
what is a harness bar?
Old Jan 7, 2011 | 05:15 PM
blue max's Avatar
blue max
I installed the tunnel insulated plate and the car seems to feel more sturdy or stiffer what ever your preference. It was easy although I have a lift. You do NOT have to remove the entire exhaust system to do it.
I also did it to reduce the interior heat which I think helped.
However, I also installed insulation on the entire car about the same time.
Old Jan 7, 2011 | 05:47 PM
C U IN REARVEIW
worth the $ in your opinion? $240
Old Jan 7, 2011 | 09:29 PM
jsilvz's Avatar
jsilvz
My opinion, yes it was.
Old Jan 7, 2011 | 11:44 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
I had an extra stock C6 plate laying around so I added it to mine just for the heck of it, essentially doubling the thickness. I couldn't tell any difference.
Old Jan 8, 2011 | 03:52 AM
BSSN's Avatar
BSSN
I wonder if there is a placebo effect, or if anyone has somehow measured torsional rigidity before/after.
Old Jan 8, 2011 | 07:28 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Placebo.
The true test would be before/after times on a road course.
Old Jan 8, 2011 | 08:59 AM
BSSN's Avatar
BSSN
Originally Posted by dave pawlowski
Placebo.
If the driver felt more confident, they would push deeper into the corners.
I think the only truly accurate way is some form of torsional rigidity testing.
Old Jan 8, 2011 | 11:11 AM
HOXXOH's Avatar
HOXXOH
A quick, but not necessarily scientifically precise test would be as follows.
Put four pucks in place at the standard locations.
Jack up the car at one location until both wheels of that side were off the ground.
Measure and record the distance from all 4 pucks to the ground.
Remove the stock plate, replace with the thicker one, and repeat the above with the jacking puck at the same height.
The difference of the other 3 pucks, if any, will tell roughly if the torsional stiffness has changed.
Old Jan 8, 2011 | 02:26 PM
timd38's Avatar
timd38
All I know is that my Snicker bars don't melt in the center console after I installed one.
Old Jan 8, 2011 | 03:06 PM
JLinCA's Avatar
JLinCA
I agree. I noticed an immediate difference with the roof off.
Old Jan 8, 2011 | 04:00 PM
BowTieBlood's Avatar
BowTieBlood
I went ahead and had one installed when my headers went on. I questioned the benefit as well, but I can tell you that driving through my parking garage is better now. The garage has random changes in incline and direction of the incline and the car makes significantly less noise now when driving up that thing. Worth $200? Who knows, but that one little factor made me believe and so that made it worth my money. I might add that I didn't expect that factor to improve, which is why I noticed it in the first place.
Old Jan 8, 2011 | 04:13 PM
victorf's Avatar
victorf
Default Tunnel Plate
Out of curiosity. I made mine out of 3/8" thk. T6. Its 3 times the stock thickness.
Unless a person is objective! PLACEBO EFFECT IMO.
Rigidity reinforcement? :-
1. Consider the location of the tunnel. Its at the middle and narrowest part of the already stout C6 frame. Further tied together with webbed aluminum front and rear sub-frames. Not much improvement can be done or felt here for amateurs.
2. Consider the method of tunnel plate fastening. 36 non structural Tiny fasteners secured plate into mostly tacked on sheet metal tangs along both side of the frame.
Heat deflector? :-
Most of the heat is conducted and radiated from the clutch and drive shaft which are located behind the tunnel plate. Try touch the drive shaft even with the car shut down for an hour. Stock tunnel plate is sufficiently serving its purpose.
IMO. Another marketing hype. Unless you make your own, its not worth the money. Then again its your money, go for it if it makes you feel.....that is why so many profile is an advertising bill board.
Old Jan 8, 2011 | 08:48 PM
timd38's Avatar
timd38
Heat deflector? :-
We will have to agree to disagree. This not a scientific test, but before I had a ceramic coated tunnel plate, candy bars melted in the center console and after they did not. Also the roof creaked before and didn't after. I can't remember were I bought it but it was worth the $90.00 I paid.
Old Jan 8, 2011 | 11:26 PM
JLinCA's Avatar
JLinCA
Placebo? So a person is going to think the car is stiffer because they want it to be? That is one of the stupidest things I have heard on here. Maybe YOU just couldn't feel a different
Original poster, I guess you are going to have to make up your own mind on this one.
MANY people on here have given this product a thumbs up. Including myself, and I am not one of those people who are going to endorse a product that doesn't work just because I bought it.
If I didn't notice a difference I would have taken it off and sold it. I don't work for the company, I have nothing to gain by keeping a product on my car that doesn't do what it is supposed to do.
To tunnel plate
Old Jan 8, 2011 | 11:55 PM
studiovette's Avatar
studiovette
sandwich 2 stock plates together with a heat shield/mat around it. much cheaper and same effect.
Old Jan 8, 2011 | 11:59 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
If you check post 7, you'll see the poster added a second stock plate (no heat shield) and felt no difference.
San
Old Jan 9, 2011 | 02:49 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Tunnel plate benefits
I replaced my stock tunnel plate with a 1/4" Elite Mfg. I also used LG Motorsports Heatmaster insulation panel. After the install, there were actually (3) benefits which I noticed.
l. The roof creaking noise was gone--totally.
2. The car felt like it was on a more solid platform (best way to describe).
3. There was a definite temperature difference in the center console i.e. lower temperatures so that my sunglasses weren't hot and my chewing gum chicklets weren't hot. (I love Snickers but I don't keep them in the car. I wolf them down before I get into the car LOL)
As for the heat transfer IMO, I think MOST (not all) of the heat emanates from the exhaust.
I'm happy with the results and consider it a worthy addition.
